analogue sensor to CAN?
  • analogue sensor to CAN?
    I want to install an EGT sensor on my truck, but I want to continue using my SCII for trans temp, oil temp and IAT and not have to install an additional gauge. I am looking for some small device that would be wired to the CAN bus, accept the input from a temp sensor and then allow me to query that over the CAN bus. I'd pick some header value that is likely unused by the truck (0x7FF) and when I query that with a mode and PID, it will return a 2 byte value that will indicate the rading of the temp sensor. I thought I saw something like this at one point, but I cant recall. I'm not much of a hardware designer so I'd like to find something already built.
    This is the closest thing I have found so far. I also found the source code, but I'm looking for something already packaged.
    http://www.moscoso.org/pub/info/book...ork%20Node.pdf
      if You are ready to program a PIC, then the cheapest "complete" hardware solution is a chinese ELM327 clone: PIC18F2480/2580 with integrated CAN controller, MCP2551 CAN transceiver, FT232 USB to serial chip - just solder some thin wire to the smd legs / pads and write Your own code for the PIC...
      http://www.dealextreme.com/p/obdii-u...e-dc-12v-42827
      http://www.dealextreme.com/p/elm327-...ner-tool-28528
      "case": Skoda Superb Elegance 1.8T
      Asrock G41MH-GE, E2180 2GHz dualcore, 1024MB DDR2/800, Samsung F1 750GB/7200RPM/32MB, M4-ATX, Lilliput FA1011 HDMI touchscreen, ASUS Xonar DG PCI, homemade Quectel L10 USB GPS
        Alex,
        How soon do you need it, and how small do you need it to be? We can probably hack ECUsim code to do what you want, and use it to program OBDLink S (its hardware is very similar).
        Vitaliy
        OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
        Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
        You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
          Time isnt really an issue and size isnt that important as there is a good bit of space behind my dash. Its a personal project and I'm going to try and have the thermocouple hardware and amp by the end of the month. This is the data sheet of the amp I plan to buy. http://www.analog.com/static/importe.../AD594_595.pdf
          Do you think this is all compatible with the OBDlink HW?
            Wow, that CAN bus node project is COOL.
            You could add sensors to the node an query them via your own person CAN code, right?
            Want to:
              That is the idea, yes.
              I have a CAN to analog dev kit coming (http://www.phytec.com/products/can/c...-eval-kit.html), but the cost to reproduce it would be a bit pricey at 139 for just the CAN piece(http://www.phytec.com/products/can/c...kmicromod.html). I think Vitaly's idea of using the OBDlink is cool and will be cheaper, but I'm not sure how many sensors he can support.
                Hey Aberk,
                Cool project. Did you make any progress since?
