CAN Mode 3 DTCs
  • CAN Mode 3 DTCs
    Hi!!
    I am trying to implement the CAN mode 3 (DTCs). I am using the software ScanMaster-ELM and Digimoto to do the tester.
    When I send a request 7DF 8 01 03 00 00 00 00 00 00 where 7DF is ID, 8 = n bytes of the CAN frame, 01 additional bytes, 03 is the mode 3
    I want to response, for example, with 7E8 8 04 43 01 02 34 AA AA AA, where 7E8 is ID, 8 n bytes, 04 additional bytes, 43 is mode 3 response, 01 number of DTCs, and 02 34 is the DTC P0234.
    When I send this response to the programs, ScanMaster and Digimoto do not detect the response.
    What could be happening?
    Are you trying to build an ECU simulator?
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
      Yes, I am trying to build an ECU with all modes with CAN protocol
