Canbus + Citroen C4
  • Canbus + Citroen C4
    By canbus can get all the info of the car?
    I ask because I'm about to buy a usb receiver for use in canbus citroen c4, and how this car is fully integrated into the system wanted to take some questions
    You can get all the information and control the radio is integrated into the onboard computer? this in turn is integrated into the rear parking sensor and it is integrated into the car system that brings the information consumption and instantaneous medium?
    Hi,
    Though the diagnosis connector I'm sure you can access to "confort" CAN bus. What I'm sure, you will be able to see engine bus, with ABS, ESP and Engine information
    What kind of USB receiver you will/do have?
    www.outilsobdfacile.com
