Time between bytes in ISO 9141-2 and KWP2000
  • Time between bytes in ISO 9141-2 and KWP2000
    I am building an ECU simulator. How much time should pass between byte and byte when the ECU transmits a message?
    For example, if the request is : 0x68 0x6A 0xF1 0x01 0x0D (pid =0x0D)
    the ECU´s response is: 0x48 0x6B 0x10 0x01 0x0D 0x12
    For example, between 0x48 and 0x6B. How much time is there?
    The bulk of your questions can be answered by reading the appropriate standards. In this case, it would be the ISO 9141-2. There are dozens of timing parameters that you need to know to build an OBD simulator, do you seriously intend to create a post and ask for each one of them? Yes, the spec is not free (it's ~$30, IIRC), but you need it to do your project. Save your lunch money, buy the document, and stop wasting bandwidth with RTFM-type questions.
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    — Need to look up a diagnostic trouble code? Try the most up-to-date, free!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]
