How does OBDII protocol works?
This topic is closed.
  • How does OBDII protocol works?
    Hi,
    I'm trying to understand how the OBDII protocol works.
    If I connect an OBDII dongle, how does it collects the data?
    Does it only listen on the bus and collect the data as it passes? or does it send a data-request and gets an answer?
    What else can I send to the engines computer other than MIL light reset? anyone knows a list or something?
    Thanks!
    You need a combination of Hardware and Software. The hardware is a cable between the diagnostic connector and the device that runs the software for reading codes and/or data. It doesn't matter whether you use a PC-program or a dedicated scanner.
    OBDII provides ways for reading/clearing codes and reading all kinds of data - live data, test results and ecu information.
    The way it works is the scanner will ask a question and the OBDII legislated ecu's (engine and automatic gearbox) will answer.
    Have a look here: http://www.mp3car.com/engine-managem...is-obd-ii.html
    and here: http://en.wikipedia.org/wiki/OBD-II_PIDs
      Thanks alot!
