Dual-speed CAN
  • Dual-speed CAN
    Hey guys,
    I'm doing a telemetry project on my car, trying to collect and log a bunch of data using a carpc. I've got a kind of a unique situation on my hands, though: my car has 2 CAN busses, running at different speeds. One is car-wide, moves a lot of temperature and acceleration data, and runs at 500kbps. The other is the datastream from the ECU, and it runs at 125kbps.
    Does anyone know if something like a ValueCAN, that has two inputs, would handle the dual speeds okay?
    Thanks!
    hello,
    My interface has two CAN inputs , but one is SWCAN.
    Do you need to process both at the same time?
      Yes, I do need to process concurrently
        Two ValueCANs?
        OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
        Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
        You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
          Two ValueCANs would strain my budget. Is it not possible to use the two channels on the ValueCAN at different speeds? It seems like it should be...
            As far as I know, you can only monitor one channel at a time. Two OBDLink SXs would run you $100:
            http://store.mp3car.com/OBDLink_SX_2..._p/com-145.htm
              ValueCAN can do two CANs.. at the same time.. there are two versions a 1x and 2x the 2x is called the ValueCAN3 (don't ask).
              Just go to intrepidcs.com...
              Hack your car's CAN BUS at www.canbushack.com
                I am rethinking my approach... so wondering if there is a wireless (WiFi, BT) version of OBDLink that would withstand full utilization of 500k bus for let's say 2 hours without "Buffer full" incidents or even worse with quiet loss of frames.
