MegaSquirt ECU and CarPC
  • MegaSquirt ECU and CarPC
    I am working on my project ('73 Louts Europa with Zetec) and was wondering if there is a way to control a MegaSquirt ECU from my CarPC? I would like to have full control of the ECU from the drivers seat and on the move, as well as having a fully digital instrument panel.
    Enter the LOTUS...
    (more info here)
    Pre-build thread
    Planning: ::::::::::::
    Parts: ::::::::::::
    Build: ::::::::::::
    Test: ::::::::::::
    Install: ::::::::::::
    Oh, yeah, and build the car... ::::::::::::
    Bump. Anybody have input on how to do this?
    Enter the LOTUS...
    (more info here)
    Pre-build thread
    Parts: ::::::::::::
    Build: ::::::::::::
    Test: ::::::::::::
      Why don't you check TunerStudio?
        Okay, so after playing around with TunerStudio for awhile I have noticed it has no speed read out, is there a way to add a speedometer function to the dashboard in TunerStudio?
        Enter the LOTUS...
        (more info here)
        Pre-build thread
        Parts: ::::::::::::
        Build: ::::::::::::
        Test: ::::::::::::
          Well I am not sure that you can't show speed in Tuner Studio, however I am not very familiar with it so I can't be sure about it..
          You can write your own software for MS and read speed howvere this requires programming skills..
            After playing around with TunerStudio I have decided that I would like to use it as a primary dashboard run from a carPC, and for retuning purposes. Should I be considering running This system from a separate computer than I will run my GPS / Media stuff from?
            Enter the LOTUS...
            (more info here)
            Pre-build thread
            Parts: ::::::::::::
            Build: ::::::::::::
            Test: ::::::::::::
              I'm looking into running megasquirt for my 240sx when I go turbo and therefore have been looking into the same idea. My roommate happens to be an awesome programmer so we have already had a few conversations over beers and for the most part, programming a digital read out of the information should be fairly simple. I'm semi decent with the graphical side of things so I plan create the gui. The only concern I have is the idea of a desktop type computer being my only way to view gauge information, especially if it's trying to play 1080p or running a visualization from a media player.
              I'll probably build a dedicated system that will handle the one and only task of reading information from megasquirt and displaying it. Once I get more development on the idea i'll post our latest theories.
              On the fly programming was something I used to be really interested in until after reading the KA-t.org forums I found that once you get a great running tune, you really don't need to re-tune on the fly. The megasquirt can use the TPS to see how far your foot is into the gas and go from there, when you create your map, you can play with how much the tune will change based on how much gas you are giving it. Most of the veteran users suggest finding a good solid tune, and then adjusting the additional values once the car runs good and can be driven down the road smoothly. All of that tuning would be much better off with a friend driving and you sitting in the passenger seat with a laptop giving you direct control. Once you have it pretty much dialed in, there really shouldn't be need for additional tuning, unless something changes.
              But then again, that is just my reading experience from the 240 forums.
              My Blog - http://brians-240sx.blogspot.com
              Carputer Progress
              Design [||||||||--] 80%
              Install [||--------] 20%
              Software [||--------] 20%
                I had the same concerns about the reliability issues with this setup, so my plan now includes a fuel gauge, speedo, and tach mounted on the dash, and I may decide to make them retract into the dash. My intentions with the on th fly tuning would be basically just to load up different tune, like a sport mode and a comfort mode. If you are just going to run a dedicated gauge only system that could probably be done with an Arduino, but I wanted the ability to display the gauges on what ever monitor I choose, and to be able to use the drivers screen with the computer. The thought of running a VM also came to mind, to help isolate the media end of things I would run the MS programs on Linux and run a front end on a Windows VM, but to do that would require a more powerful computer. Take a look at the pre-build thread in my sig, it addresses this subject as well.
                Enter the LOTUS...
                (more info here)
                Pre-build thread
                Parts: ::::::::::::
                Build: ::::::::::::
                Test: ::::::::::::
                  Originally posted by Veritas View Post
                  On the fly programming was something I used to be really interested in...
                  Why not use self tuning? (Especially if you have an awesome programmer - that assumes you can read the sensors (eg, injector squirt, O2 sensor etc, acceleration) and mod the running map.)
                    That's an interesting idea. I figured I would just leave the stock harness in the car for the OEM gauge unit and if something happened I could just swap it in and be back to stock in a heartbeat.
                    I was thinking the same thing, until i came across the following information on their site.
                    MegaManual :: Switching fuel maps for a single type of fuel is an out-dated "carburetorism" that you don't need with a properly tuned EFI setup (the low load part of the tune is set for economy and the high load is tuned for power; trivial with EFI, hard with carbs). The 'switch' is the throttle pedal. MegaSquirt® can detect when you want more power (with the TPS and MAP sensors) and make the 'switch' on its own. If you've got the throttle almost closed and are cruising down the freeway, a well tuned MegaSquirt® will lean things out for maximum fuel economy. Then when you floor it, the sensor readings change and MegaSquirt® will go into the full power section of its tuning.
                    I was thinking about an Arduino setup, but the Arduino is really limited in the ability to output information onto a digital screen directly. I've seen lcd controllers up to three inch but I'm looking into running a 7" setup in my guage cluster area, similar to this setup . My only challenge is that I don't have OBD-II so I will have to get all my information from megasquirt.
                    My friend and I are looking to see if they have an API for megasquirt. Once we figure out what language to use, it will be fairly simple to set it up. I plan to use a dedicated system, running a version of linux without running the gui. Should lead to quick load times and also won't have the overhead of running anything other than the gauge program itself.
                    I'm real hesitant to trust a vm as it still relies on the host system staying up. I'm not sure how the vm would feel about constantly being shutdown due to the host powering down or getting put into standby as the host system goes into standby. And a system that would need to be the host is going to draw quite a bit of power. The advantage of a VM though is quick rebuild and reboot times.
                    I've considered that as an option but in their manual they advise that it takes a lot of "By the seat of your pants" tuning to get things right. Parameters and math are great tools, and will allow you to dial things in pretty closely if you understand all the variables your looking at and know how much each adjustment will effect everything but to program an auto tune would, IMO, lead to a very weak tune that simply keeps the car running, similar to what a stock tune on a stock ecu does. I've read many threads of members tuning and then re tuning, and then continuously re tuning, just to dial things in perfectly.
                    Carputer Progress
                      [QUOTE=Veritas;1468744]
                      Not really limited in size, but in cost:
                      http://www.reachtech.com/
                      How large do you want it?, and how much are you willing to pay? heh.
                      RevFE
                      My Shop
                        Can MS also handle changes in other parameters, like altitude and fuel octane? There are ways to drive a bigger screen from an Arduino, but its not very easy. As for the GUI look at TunerStudio and MegaTunix, they both have the ability to run a dash type display from the MS, even if you don't use them for tuning after you get your tune set, it would save you a lot of work writing your own program
                        Enter the LOTUS...
                        (more info here)
                        Pre-build thread
                        Parts: ::::::::::::
                        Build: ::::::::::::
                        Test: ::::::::::::
                          I like the info Veritas posted - especially about multiple memory maps being out of date.
                          LOL - I think of those that keep bragging about Haltec's 16 or 32 maps. I simply ask (how do you select which map....?". They still don't get it!! (Not to metion how each is tuned - is it only valid for that ambient temperature and pressure and testing (dyno) setup?)
                          But self-tuning cannot be worse than the mapped map - it can only improve it.
                          Though self tuning could occur from no map, normally it would start from some base map.
                          Since all the relevant variables are known or can be ascertained (except arguably perhaps inclination), the vehicle has its own dyno and can itself tweak different values, measure the results, and store them if it's a improvement.
                          Normally at least 2 or 3 maps are desirable - eg, normal, economy, and race. Lean burn is another, though it is fraught with risk, and is illegal in some places (eg, Australia).
                          Race typically increase injector squirt by 10%. Economy sacrifices torque & acceleration for lower fuel consumption.
                          But there can be any number of user defined desirable maps - eg, constant velocity (economical but will maintain speed up a hill) though that arguable is a Auto-Cruise issue.
                          Irrespective, each can still have their auto-learning/self-tuning manipulations based on the user's desire. Race for example may desire x% better performance from eg 10% extra fuel, but may reduce the 10% factor if some rule is not met (eg, unless gain is y%, don't waste the extra fuel).
                          Whilst for many the difficulty is contemplating how to self-tune (many say it's impossible LOL!), I see the difficulty as deciding what self-tune rules to use.
                          The rest is easy, though finding the time for the coding would indeed be difficult... (Though basically "simple", it requires extensive thought & coding.)
                          But to go to the trouble and expense of having maps dyno tuned only then to hit the road or racetrack in different weather conditions, or slightly different fuel, or later, worn injectors etc.... What a waste when you have all the dyno info at your fingertips.
                          BTW - I have only considered raw CPU encoding for EMS/EFI functions. PCs or Arduinos etc were totally unsuitable (real-time, other interrupts and OS processes, and too slow!) though for gauges etc they are fine. (But maybe PCs etc are now fast enough? But I'd hate the "non-dedicated" breakdown.)
                            Hey BoyRacer,
                            Not sure if you heard about this but I plan to use it in my system.
                            Raspberry Pi
                            It's a small SoC that is capable of out-puting 1080p for $25 w/o Ethernet and $35 w/ethernet.
                            Working with my friend, we are looking at setting up Megasquirt (engine management) ----> Arduino (reading serial and forwarding information. Also will read information if screen goes down and display warning lights if needed ) ----> Raspberry PI (Receive data from arduino, display digital guage. If fails data read rolls back to arduino.)
                            I'm not sure if tuner studio will work in linux but if it does, this could be a cheap, dedicated system, with great uptime and low power consumption and overall awesome flexibility. Even if the system fries, $25 and your back up and running.
                            Carputer Progress
                              Yes I have heard about the RPi, there is a thread for it here http://www.mp3car.com/general-hardwa...pberry-pi.html Im not really planning anything with the RPi yet, as I probably wont be able to get one until mid summer. But with the GPIO headers on the RPi you wont need an Arduino or Fusion Brain or whatever, it has that capability built in.
                              Enter the LOTUS...
                              (more info here)
                              Pre-build thread
                              Parts: ::::::::::::
                              Build: ::::::::::::
                              Test: ::::::::::::
