Odometer Conversion
  • Odometer Conversion
    I am in the process of exporting my Volkswagen Caddy 2007 overseas and need to change the mileage travelled from miles to kilometers, can anyone tell me what software and cable I would require to achieve this.
    Any help will be appreciated
    You would need VCDS from Ross-Tech to do this.
    The kit will also be able to read all systems in your car - fault codes and live data, etc.
    If you do not plan on using that you would be better off (cheaper) by having somebody do it for you.
      Thank-you for the info
      Do you perhaps know what the process would be once I have the VCDS to change from Miles to Kilometers?
      Thanks Again!
        I think coding in Instrument cluster. Set country to Europe.
        See: http://wiki.ross-tech.com/wiki/index...Caddy_%282K%29
