CAN bus sniffing hardware / software recipe
  • CAN bus sniffing hardware / software recipe
    Hi,
    what is the best hardware and software setup (reasonably priced) one could use to sniff a testor and analyze CAN BUS data?
    an obd-ii splitter cable and IPSecMsgMon? I am unable to locate that program anywhere
    I use http://www.scantool.net/obdlink-mx.html and a custom software I wrote, called ObdTool. Unfortunatly there are no windows binaries available, so you have to compile from source which is none too easy, but eventually I'll have some available. If you're on linux, it will be much easier to compile: http://gitorious.org/libobd/obdtool
    RevFE
    My Shop
      I see but I am trying to sniff a testor tool to get the Extended PID of mode 0x21. The ecu ROM has been modified and the company behind it confirm me that the PID were custom.... so I need to run the "testor" and to sniff at the same time...
      Mart
        this one
        http://www.8devices.com/product/2/usb2can
          does this work for sniffing a testor tool?
          http://www.amazon.com/OBDII-Splitter.../dp/B000TMCX72
          Mart
            Is it the same device as the Peake USB-CAN?
            What software does it come with?
            OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
            Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
            You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
              Yes it is. This one is the cheapest I can find so far.
              I have already ordered one.
              Check the downloads page to see the library.
              http://www.8devices.com/product/2/usb2can/downloads
