VCDS on my iPad
  • VCDS on my iPad
    Hi there all members. I'm new to this wonderful forum. I have been using VCDS on my laptop for a good few years. I would like to know if it's possible to install VCDS on my iPad and running my interface from it. If it is indeed possible, how would I go about doing so. Many thanks. Keep well.
    Not possible according to Ross-Tech: http://ross-tech.com/vag-com/faq_1.html#PC-Requirements
      Thank friend. I also saw that on their website. But nowadays we get so many computer skilled technicians that know how to manipulate computer systems to make them work for whatever reason. Many thanks for your reply. Keep well.
        Hi there, any other member mind to share opinion. Many thanks.
          Check their faq, your question is answered within.
            Thanks friend. Do you mind sharing what exactly is said. I have search, can't seem to find answer I'm looking for. Many thanks. Keep well.
              http://www.ross-tech.com/vag-com/faq_1.html
              1.9 Will there be a version for iPhone/iPad, Android, Blackberry, or Windows Phone 7?
              We are not planning to make a native "Application" for any of these platforms. Instead, we are working on an approach to support modern mobile devices in a completely platform independent way. We've made pretty good progress on this project recently, but we do not yet have a firm date when it will be available. Rest assured that we won't keep it a secret when it's ready!
              In the meanwhile, the most portable way to run VCDS is to use a Netbook PC. These are small enough to fit in your glove box and cost less than a typical smart phone. Current ones usually come with Windows 7 Starter Edition, and VCDS works fine with this. Older ones normally came with XP-Home and VCDS works fine on that as well.
                Thank you.
