Engine Link App for iPhone
  • Engine Link App for iPhone
    Engine Link - OBD II vehicle monitoring and diagnosis for iPhone (http://appstore.com/enginelinkobdiiv...nganddiagnosis)
    It has Full custom PID support, Formular support and configurable GUI.
    FEATURES:
    + Show and reset a DTC / CEL / fault code like a scan tool
    + Graph data
    + MPG widget to plot real time fuel efficiency
    + Heads up display / HUD mode for night time driving (mirror the display on your vehicle's windshield)
    + Can read Transmission Temperatures (vehicle dependant)
    + Horsepower/HP & Torque / acceleration
    + Boost / vacuum gauge
    + Engine speed / Engine RPM / Engine Load /Coolant / Fuel Tank
    + Customizable dashboard
    + Full configurable GUI with user choice of dial gauge, bar gauge, plot gauge, digital gauge, and on-off gauge as display elements
    + Full custom PID support.
    + Formula support.
    + Preloaded GM and Ford PID libraries
    + Preloaded standard PID library and Prius PID libraries .
    + User can add more libraries within the app or by using iTunes File Sharing
    + Multiple ECU support. Non-CAN, 11-bit CAN, and 29-bit CAN ECU bus types
    + Multiframe data support
    + Background color option
    + Email user log function (access by long pressing custom PID screen)
    + Multiple PID formula support
    Screenshots for EngineLine App:
    Click image for larger version
ID:	2285410Click image for larger version
ID:	2285411Click image for larger version
      Originally posted by Reviewer
      don't listen to the bad reviews complaining that the app doesn't work with their Bluetooth adapter--it's right in the description that you need a wifi obd2 adapter.
      Originally posted by App Description
      With an ELM 327 OBD-II WiFi adapter...
      *** If you have bluetooth OBD adaptor, please contact [email protected] for instruction before you purchase this app.
      Looks pretty cool, but I only have a BT ELM327. Works great with my TouchPad running Android, but the iPhone BT stuff seems to be locked down. I'll see how they respond to the email.
        Their support confirmed what I thought. "iPhone has restriction on Bluetooth support (Basically iPhone requires BT data device to have a special Apple authentication chip which 99% of the BT adaptors don't have)." To make the iPhone work with an unauthorized BT device, they say to jailbreak the phone and install roqyOBD, which is described as a free add-on for roqyBT (5 euros for a license).
          More new features were added in EngineLink version3.8:
          Save and load your custom layout. You can easily share your cool interface with others.
          Added support for Bluetooth Low Energy OBD-II adapter. There is no restriction for Low Energy Bluetooth. It is Auto configure, auto connect.
            Custom screens.
              Thank you!
              The app now supports Bluetooth Low Energy Bluetooth. No jailbreak is needed.
                New features added to version3.9:
                0 to 60mph timer and quarter mile timer. You will know how fast your car is.
                Checking history trouble code. This would be helpful when buying a used car to see if there was any recent history codes.
