ECUsim 2000 and ECUsim 5100 firmware updates (software control)
  • ECUsim 2000 and ECUsim 5100 firmware updates (software control)
    A few developers on this forum own the ECUsim 2000 and ECUsim 5100 OBD simulators. We've just released a free firmware update, that adds a boatload of new functionality:
    https://www.scantool.net/updates/ecusim2000/
    http://www.scantool.net/updates/stsp300/ (for ECUsim 5100 users)
    The update will allow you to:
    • Add/delete ECUs
    • Set ECU parameters: address, CAL ID, VIN
    • Create custom PIDs and change their value at runtime
    • Add/delete DTCs and Freeze Frames
    For a complete listing of all commands, see the Programming Manual.
    Best regards,
    Vitaliy
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    Excellent! This is the way all hardware companies should be run. Keep up the great work Scantool! SNO
