Communication with OBD-II using Windows Phone
  • Communication with OBD-II using Windows Phone
    Hello, I have a problem with sending and receiving data from elm327 device.
    I tried to connect to the device using channel 01 (on Bluetooth) but it doesn't matter what command I send, I just receive the string "AT+BRSF=24\r" as an answer.
    I tried also to connect at channel 16 and there I receive a string "NO DATA"
    somebody knows what is the problem?
    thank you,
    Arie
    Update:
    When I try to connect to the OBD device using "OBD Doctor" app (http://www.windowsphone.com/en-us/st...8-27735854493c)
    it make a step that says "Initializing the device" and then it's connecting.
    When I try to use my app after "Initializing the device" it works.
    Someone knows what does that step?
    thanks,
    Arie
      Update:
      thanks,
      Arie
