does my car have odb ii
  • does my car have odb ii
    my car is a uk peugeot 306 1.4l model and was woundering if this was obd ii, its a 1996 model and i have searched for the connector but am unable to find it.
    any help would be most greatful
    Martyn ( www.essentialcruise.co.uk )
    I know that all 1996 and newer cars are supposed to have OBD II, but Im not sure if that applies in europe. I also know that all of the ports have to be within 2 (i think) feet of the steering wheel, and labeled. Your manual should describe the location if you have one in the car.
    There is some info here: http://www.obdii.com/connector.html but it looks like the rule was only for US.
    Progress here: http://www.siriuscybernetics.net
      European cars don't have OBD-II until 2001, diesel engine ecu is not until 2000
      Jan
      Not doing carpc anymore
        obd2 port must be within 1 meter of the steering wheel.
          And accessible without any tools.
            _dopehead_ wrote
            European cars don't have OBD-II until 2001, diesel engine ecu is not until 2000......
            do'h wanted to do some stuff on it too.....
              Does anyone know if the 1988 Toyota Corolla FX has ODB-I or ODB-II? Where would I check?
                88 Corolla will have ODB-I.
                In US, only 96+ cars are required to have ODB II. Period. ODB III is in post deveploment stage and last time I heard, they are going to deploy that by 2006.
                - Lwin M. Maung
                If it's stuck, force it. If it breaks it needed replacing anyway
                  how can i tell if my mx6 has obd-i ???
                  www.caraudioaustralia.com
                  come and check us out !!!!
                    1. What year is it?
                    2. Is it in the US?
                    3. If you look around the driver side (often times, it's hidden), do you see a connector that looks like this?:
                    - Lwin M. Maung
                      ok, well its an 89 mazda mx6 gt
                      its in australia
                      never seen a connector like that near the driver side
                        That would be a pre Obd2...I think its called a M.E.C.S on a Mazda
                        2005 Ford Focus ST
                          anyone have any idea what i need to do to extract infomation from it ???
                            Cant do much while the engine is running with mecs as far as I know. Let me rephrase. You can read what has happened as far as codes, or put into a test mode while running, but it is not like obd-2. Obd-2 is a real time type system, whereas you cant really monitor pids (paremeter identification), or look at real time info on earlier systems. I am going off of the mecs systems that are used on the Probe, a close cousin, with Ford diagnostics (NGS). Someone with a mecs scan tool may be able to provide more info, but from a "I know what works on a 89 probe" standpoint, it wont get you very far in looking into anything but trouble codes.
                            2005 Ford Focus ST
