Great OBDII Solution
  • Great OBDII Solution
    Im new here, but im about to build a carputer, (waiting on all the parts).
    Anyway.. I wanted to tell you guys about a wideband + datalogger setup that you could mount directly into your computer if you use one of the larger computer setups.
    http://www.wbo2.com/
    Check it out and let me know what you think.
    James
    I think I want it. Added to my Wideband O2 favs folder thanks!
    Fabricator
      Sorry about my ignorance, but what exactly is this? Is it only for oxygen sensor data logging, or can it gather other OBDII info too?
        It will read real o2 values with a wideband o2 sensor, a must for anyone who modifies their car heavily. You basically use it to tune.
        At the same time, the setup can datalog your car's sensors.
        Basically you can see your air/fuel ratio compared to such things as RPM, boost, air intake temp.. etc..
        Perfect for tuning.
