Is this a OBD-II socket ?
  • Is this a OBD-II socket ?
    ok I have a renault Laguna 2002, under the ashtray theres this plug
    now does this look like a OBD-II ?
    if so.. I'm after a bit of kit and software to enable me to display info on my screen.. any ideas ?
    cheers
    CdR
    Follow me on Twitter
    http://www.FreeICE.co.uk
    It looks like OBD2 to me, but I'm no expert.
    http://www.arizonasportcompacts.com
      im guessing so too, but a quick trip to te mechanics and youll get a deffinete answer.
      It aint no family car.
      SEE MK2 At : -
      http://www.mp3car.com/vbulletin/showthread.php?t=22810
        looks like it to me.
        Car: 2000 Audi A4 Avant 1.8t
        Carputer 2.0: removed. Back to stock.
          Borrowed from autotap faq...
          Your vehicle must have an OBD II connector that looks like this:
          and has pin combinations representing one of the four OBD II protocols:
          J1850 VPW – The connector will have metallic contacts in pins 2, 4, 5, and 16, but not 10.
          ISO 9141-2 – The connector will have metallic contacts in pins 4, 5, 7, 15, and 16.
          J1850 PWM – The connector will have metallic contacts in pins 2, 4, 5, 10, and 16.
          KWP2000 (ISO142300) – The connector will have metallic contacts in pins 4, 5, 7, 15, and 16.
          The pins are used in the following way:
          Pin 2 - J1850 Bus+
          Pin 4 - Chassis Ground
          Pin 5 - Signal Ground
          Pin 6 - CAN High (J-2284)
          Pin 7 - ISO 9141-2 K Line and ISO/DIS 14230-4
          Pin 10 - J1850 Bus
          Pin 14 - CAN Low (J-2284)
          Pin 15 - ISO 9141-2 L Line and ISO/DIS 14230-4
          Pin 16 - Battery Power
          If your connector has extra pins, don’t worry. Manufacturers can use them as they see fit.
            thanks fella.. looks good :-) just got to decide if autotap is worth $200, I mean the only benefit really is so I can show off to my m8's.. lol
              No need to spend $200 when you can spend $99. Check out Digimoto.com
              http://www.digimoto.com.
              Digimoto enables you to do 0-60 & standing 1/4 times, as well as plot power & torque.
              I ordered online, their Elmscan ISO interface, software & cables. Works fine on my Rover45TDi. Took just 5days to arrive and including 14 UK vat, cost 85 - you pay the vat when collecting it from your local Royal Mail sorting office.
              Just check which protocol you need as they do offer interfaces for all 3.
              You can download free software to use with the interface from:-
              http://www.Scantool.net
              http://www.wgsoft.de (digital dashboard display)
                Does the digimoto software update as fast as it shows in the flash demos? I've seen some other OBDII software and it updated slower than this.
                  I believe it depends on how many sensors you are looking at.
                  Dual Lilliput's 70NP/C/T
                  Syntax SV266AD KT266A
                  AMD Athlon XP 2000
                  Viking 256MB DDR
                  D-Link Wireless 802.11B
                  Seagate 120GB
                  OrbitMicro 250W DC/DC converter
                  SII Wireless Audio Link
                  Digimoto OBD-II
                  Earthmate GPS
                  BU-303 USB GPS
                  D-Link Bluetooth
