any interest for a cheap obd2 reader?
  • any interest for a cheap obd2 reader?
    i just made my own obd2 reader, it uses the elm chip it is designed for iso format euros, imports. If enough people are interested i will have some nice pcb boards made up for these. They should be about 2"x1" if everything fits right, able to plug directly into the back of the computer also. Im thinking they will cost about $40-50 for a completed reader. obd2 cable will be about $17. if people are interested let me know and ill get things rolling. I will also be designing the pwm and vpm for domestics also.
    interest - yes
    I'm not in the buying phase yet, but when I get there, I'll find you.
    I consider that our present sufferings are not worth comparing with the glory that will be revealed in us.
    www.neoterikos.com
      do they have all of the features of a normal obd2 reader? i don't know a whole lot about obd2 just yet (havent read a whole lot on the obd section), but if they are then im interested cause i dont want to spend $200 or whatever it is for a normal one.
      CarPC install is starting to come along again...
        yeah I'm interested, also would be prepared to be the sole uk import person for these and the send em to everyone else here, if you marked em for $10 value then no import tax would be charged :-)
        Follow me on Twitter
        http://www.FreeICE.co.uk
          Yeah im curious what this might NOT do compared to the more expensive ones out there....
          Vehicle: 2003 Mistubishi Evolution
          PC Specs: 1gHz Nehemiah M10000
          512mb RAM
          Windows XP Professional
          80gb 7200rpm 8mb cache HDD
          UI: MediaEngine 2.1
            I am in aswell, if they offer all the good stuff...not sure what that is though. Also what software will we be using with this.?
              I'm interested also....
              I would just like to see what software it works with and a comparison of how it stacks
              up to the other OBDII products out there.
              CarPuter: Dell P3-500 Laptop; D-Link WiFi; Deluo GPS; D-Link Radio; iMac DVD w/ ide2usb
              Audio: Audigy 2 NX; Kicker KX700.5 amp; 20w center amp; Kicker L7 10" Sub
              Display: Lilliput 7" TouchScreen
              CarPuter Install
                I'm also interested to see what type of software we're working with here.
                I've been looking for a while now for someone with the VB code to take the OBD data into a usable format, but everyone I've talked to either has an incomplete program, or charges lots of $ for it. Basically I want to take their program and develop a flash front end for it. If anyone has anything along these lines, let me know. I'd be happy to share the front end when I get it done.
                www.neoterikos.com
                  I've looked into ELM products a while back, and unless they've improved them, the product is extremely limited, and IMHO its cheaper to build one of these considering they don't use any specialized parts, and many people here will most likely have everything needed.
                  In addition ISO standard does not really require ELM interface, there is a project on sourceforge.net that has software solution. Reason for that is that ISO interface can be understood by RS232 without major modifications to the electrical part.
                  Never be afraid to do something yourself. Remember - amateur built the Ark, professionals built the Titanic.
                    Could you flip the board over and take a picture of the backside?
                    Thanks!
                    Dual Lilliput's 70NP/C/T
                    Syntax SV266AD KT266A
                    AMD Athlon XP 2000
                    Viking 256MB DDR
                    D-Link Wireless 802.11B
                    Seagate 120GB
                    OrbitMicro 250W DC/DC converter
                    SII Wireless Audio Link
                    Digimoto OBD-II
                    Earthmate GPS
                    BU-303 USB GPS
                    D-Link Bluetooth
                      hmn..think you could post the schematics?
                      rebuilding carpc... kinda..
                        http://www.elmelectronics.com/DSheets/ELM323DS.pdf
                        The diagram is there
                          Heres a full OBD2 project from Elektuur/Elektor magazine :
                          Rename all the 3 files back to RAR and unpack...I cant post more than 200KB.
                          Use the document for reference or whatever...just dont blame me when things goes wrong.
                          EDIT : Look like some didnt get what I meant by rename back to RAR...What I meant is remove all the .ZIP extension so you are left with .RAR extension. Use the software WINRAR to unpack all 3 files. There should be a PDF file in there
                            the board is the same as ricky327 posted, i just made mine with a 9 pin instead of a 25 pin serial port, i am also going to be adding a turn on relay so that the unit is only powered on when the computer or car is on. There is alot of software out there, www.scantool.net is one. I am also making my own software for the interface that will be strictly a virtual dashboard. far as capabilities, this will read all the suported information that your car can provide to it, check engine codes, and clear them. I might do a usb one also.
                              what is the name of the project?
