Finally got my DFI setup! hehehehehehe
  • Finally got my DFI setup! hehehehehehe
    Well, i dont have the CarPC setup going in a vehicle yet, but I just got my DFI setup for my '88 Escort GT I had to go to this because of my unusual combination. The stock EEC wont correct for this many changes, and well, its not OBD2, so i cant really monitor what was going on. Since my motor is destroked, bored, has flat top low compression pistons, late model roller cam head, larger injectors and a turbo, it is fairly important that they all work together. Now I am rethinking putting my carpc in this instead of my Stang, i will be needing a laptop otherwise. Might as well, huh! Anyway, here is a screenshot of the digital dash that goes with it.
    Just FYI...the Accel Gen VII like this goes for about $1600-$2200 depending on the options...like mine has a 3 bar map sensor for the turbo, and will have a wideband o2 as well, another $900 option. They can only be purchased where they are being installed, but since I work there...hehehe. Still not cheap, but NICE!
    2005 Ford Focus ST
    BP turbo?
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
      In all reality I would have probably been better off with the newer BP turbo Mazda based motor, but I have always liked the old CVH motors, as well as the older boxier looking Escorts and I got very lucky and found all the rare EXP turbo manifold and turbo shell parts to make it work. The block is a '88 and the roller cam head and all the rest of the parts are from a '94 1.9L (non-H.O.). We'll see within the next couple weeks if it as all worthwhile!
      2005 Ford Focus ST
        That looks like it was programed in LabView. Am I right?
          Not really sure who Accel uses...could very well be. If so, maybe I can find some peoples to tweak my setup. For example, I have a "pro" key...which is a male to female extension that plugs into the printer port to "unlock" the program. They also have a master key,which unlocks much more function. I am sure it could probably be software unlocked but I dont know anyone that knows the language this is programmed in to begin with. Hmmmm!
          2005 Ford Focus ST
            Well, the DFI is up and running on my Turbo Escort I am having a friend fab up a mount for the Lilliput to go above the rear view mirror (these Escorts had a clock up there and plenty of room) and it should be mounted in a week or so.
            If you ever get a chance to play around with DFI...you will be amazed at what can be done. I can adjust EVERYTHING about the engine management...from simple stuff like when the fan comes on and off, to complex things like cold start enrichening and 3 stages of nitrous management.
            2005 Ford Focus ST
              Woohoo - that engine looks very familiar!
              My Fiesta RS Turbo is running an American Tall block (1900) CVH engine from the American Escort - I think that may well be the one that's in your car?
              Only trouble is mine is using the Weber Marelli management from a Ford Sierra Sapphire Cosworth 4x4 and as such is a real pig to interface with.
              I have someone who's making a microcontroller box for it at the moment so that data packets can be sent to the PC, but that's a long term goal!
              Cheers,
              Andy
                escort.... eewwwww :P
                When in doubt, moo at things.
                  What does the American Escort look like?
                  And is it rear wheel drive as the European Escort's (mk3 onwards) were all fwd?
                  Cheers,
                  Andy
                    cool deal! DFI rules. I'm throwing out all my carburetors. Do any of you youngsters know what a carburetor is? It's about 1/2 way up the scale between DFI and a toilet.
                    Anyway, I have a 2002 firebird drag car with a worked LS1 sitting in my garage. I have to completely rewire the car, while I'm at it, I'm tossing the stock ECM and installing a Gen VII. Pretty much for the same reasons you did. The car's owner saw my carputer and engine swap and he pretty much begged me to do his car. Gonna make some $$$ on this one!
                    Chris Krug
                    owner, turbine minivan
                    http://www.youtube.com/krugtech
                      Escorts ROCK!
                      <--------- My crappy car.
                      Installed.
                      -GPSSecure- - GPS Tracking
                        I have a 2001 sunfire gt
                        i would like to get some program like this to hook into my engine
                        where would i get this
                        PS I live in canada
                          err, I know what a carb is as my 1.1 runaround is fuelled by one
                            Andy
                            Its a front wheel drive...pretty much took over for the Fiesta (of which I have had 3, all '77-80's) when it was discontinued over here. I wished and wished that they would import the Cossie....never has happened. There are a few in my state but not street legal. Cant get 'em licensed.
                            anyway, here is my '88 Escort GT...
                            2005 Ford Focus ST
                              My goal is to do something like that w/ phidgets (a bit less techinical though) I have no turbo or anything of the sort.
                              I liike what U have thought. Real sexy
                              I consider that our present sufferings are not worth comparing with the glory that will be revealed in us.
                              www.neoterikos.com
