Getting 1/4 mile times
  • Getting 1/4 mile times
    I'm thinking of interfacing ODBII with my PC but I want to know if would be able to record my 1/4 mile times and speed. What software can record speed/acceleration and such. The websites I've been to dealing with ODBII seem to all have to do with trouble shooting the cars problems which I don't care much to do, I just want it to log my speeds and such.
    -Andy
    OBD-II updates are not fast enough to be able to peg down quarter mile times like this. There are some experiments using OBD-II for quarter mile timing and even in-car dyno, but the accuracy is crap. you can get better ideas measuring out a quarter mile and driving with a stopwatch.
    If you want a better in car measurement, the Passport G-Timer I hear is pretty good, though I dont use it and don't know anyone who does.
    If you want to check out the OBD-II stuff for it, look at OpenDiag the linux OBD-II stuff on sourceforge.net.. The CVS version has the dyno mode. I could not get it to work in my car, though, so YMMV.
    The best option for this would be to get an accelerometer sensor and hook that up to your carpc. If you get an accurate one and calibrate it properly, you should be able to get very good readings off of this. I might do this at some point to track my runs through an autocross track. I would interpolate GPS data with accelerometer data to derive position readings every 1/50 second or so.. would also work for straight line measurements. AFAIK, the G-Timer is calculating velocity and distance with an accelerometer as well.
    MY CAR IS FOR SALE!
    See My Project Page for Details - 2003 BMW E46 ///M3
    Custom Dash Monitor Housing - OEM Fitment
    Custom Overhead DVD-ROM Housing in Headliner
    BMW I-Bus Integration
    My homepage with many other fun projects!
      How bout getting one of those Escort G-Timers?
        -Andy
        the autoingeunity obd scanner has a dyno and 0-60 and 1/4mile program with it. not very cheap but it looks good.
          the digimoto obdii comes with a program that does 1/8...1/4.. and dyno.
          probably not 100% accurate but its 100% cool.
          lol
          2001 Acura CL traded for a 2006 Subaru Legacy GT
          7" Lilliput Touchscreen
          NANO-ITX+m1-atx
          512 DDRsodimm
          60g SATA Laptop HD
          4x Apple DVDslot
          digimoto OBDii
          mS GPS
          mini BT keyboard
          relocated HU faceplate
