SUBARU and OBD-2 ve105 -116
  • SUBARU and OBD-2 ve105 -116
    Subaru 1998-2004 have only K-line ( PIN 7 of j1962 obd-2 connector)
    I can read it with ScanTool and ELM323_chip.
    But I would like to use ve105 - ve116 soft.
    It does not work via ELM, neither via simple K-line adaptor.
    If anybody has connection with SUBARU and ve105 - give a piece of advice what hardware do u use.
    -- MOD EDIT --
    no software piracy talk here
    If what you're talking about is this, then the software is free and as far as I know only works with that hardware, whether you have the serial number or not.
    And you shouldn't be asking to trade serial #s on this forum anyway.
      Thnx for the reply.
      Did you work with their hardware?
      I have heard that ID is needed for some extra features of the soft, O2-sensor and so on. Not truoble codes.
      Do you know your MY2004 Impreza is under ISO or CAN protocol?
        I've been trying to figure that out myself. See my notes http://www.tmz.com/wrx/wrxcan.html
        Supposedly it does use K-Line (ISO-9141) and KWP-2000 (ISO 14230-4)
        I beleive the 2004 may have CAN, but not certain. If it does have it, it may not be connected to the OBD port (J1962 connector). Pins 12 and 13 on this connector may be CAN.
        I'm currently using CAN for an application at work and I'm tempted to hook up a CAN node to those pins and listen...
          I've visited www.etool.org and other sites with search.
          They all say Subaru MY2004 are CANed.
          CAN must be at j1962 pins by SAE order. (see their book HS-3000)
          Nevertheless I would like to make my ImprezaMY98 talking to Peppre's ve116 without his interface. A friend of mine works with ve116 via Uniscan using it without CPU, only as K-line adaptor.
            Well the official CAN pins would be 6 (CANH) and 14 (CANL) - my J1962 connector does not have any wires going to these 2 pins.
              yes
              right you are!
              MY2004 is Iso-9141-2
              CAN will be 2008 probably, or 2007 but not 2006.
              No.
              All these two statetments are wrong.
              The soft from A. Pepper (www.obd-2.com) does not work without serial number at all!
              I've tried to make it talks, but all in vain.
              I've gotten ID and soft talks to US Suraru 1997 via simple K-line adaptor. Subaru does not has L-line, so one can assemble only k-line with a couple of transistors.
              Log. function is amazing! I see verious PIDs of Mode01 and so on...
                Personally, I'll be using Deltadash from www.ecutek.com on my MY03.
                C!
                http://carpc.riposte.net
                I reserve all rights in connection to each post I author, without exception.
                  Delta is cool!
                  Should the ECU be re-flashed before it can talks to DeltaDash or it works with stock ECU's?
                    I'll be doing the Ecutek flash at Christmas - however Delta should work with a std ECU as well - only the software changes, not the resulting data.
                    C!
                      Delta is cool!
                      DeltaDash translates the Subaru Select protocol which updates a hell of a lot faster than the OBD2 does in the Subaru.
                      BTW, I have this in my car, in case ya'll haven't heard of it.
                        So pins 11 12 13 are ivnolved on j1962 connector,
                        not usual pin 7 (K-line) as for obd-2.
                        Unfortunately ecutek uses their "black box" interface,
                        I guess that a part of programme code is within it.
                        Hardly one manage to crack, even with "black box" available to "reverse" it.
                        It must be PIC within.
                        Noone can reverse ELM chips yet also
                          Don't need to RE the box, just figure out the protocol and electrical interface. I'm pretty sure Subaru didn't encrypt the data, so its just a matter of figuring it out and writing some code.
                            You may visit
                            http://www.xidash.narod.ru
                            It is like Delta Dash from Ecutek but it is much cheaper and works with any number of SUBARUs, not just with three.
                              You may visit
                              Be careful, I believe he's already being pursued by Ecutek for copyright infringement. I guess his "customers" could also be guilty of the same offence by buying or using his product. Check out his site and the real ecutek.com site and see how very similar they are.
                              I'm not sure I'd want to send my money his way...
                              Just my $0.02
                              Regards
                              Dox.
