List Of Programming Resources
  • List Of Programming Resources
    I know there are several people working on custom interfaces for their carpc's. I wanted to start a list of resources that are available for writing software to interface with OBD-II.
    This is a good pdf on the API: http://www.ghg.net/dharrison/OBDScanAPI.PDF
    Here's an alternate explanation of the API: http://www.obddiagnostics.com/obdinfo/info.html
    List of applicable standards (SAE books are expensive, but my library has 'em!):
    • J1978 - SAE-established standard for OBD II scan tools
      J1979 - SAE-established standard for diagnostic test modes
      J2012 - SAE-established standard accepted by EPA as the standard test report language for emission tests
    Trouble codes (OBD-II and non-OBD-II): http://www.troublecodes.net/technical/
    and http://www.obdiicsu.com/Docs/DTC/DTCData.html
    For those working at the hardware level: http://www.elmelectronics.com/thehome.html#ELM320
    Some more hardware fun: http://www.obd-codes.com/howto/index.php
    What other resources (standards, SDK's, libraries, tutorials, etc...) do you know about?
    J2534 - SAE established standard for "Pass through Reprogramming" of new vehicle ECUs through a generic hardware device. Flash programming files are available via each OEM, usually via their pay to use web site or via CD subscription.
      Scan Tool: http://www.scantool.net/obd_information.htm
      Looks to me like the same API as the others...From what I can tell, they all use the same API. Someone please correct me if I'm wrong and post the API.
        Hi!!!!
        I need your help please!!!!
        I am writing code in Visual Basic in order to communicate to the ECU with ELM interface. I donít know very well how to write and read the commands I have to send/receive to talk to the ECU.
        Could you help me please?
        Iíll appreciate your help!!!
        Regards
        e-mail:[email protected]
        Esteban
