Alternatives to OBD
  • Alternatives to OBD
    I have a 1990 vehicle so basically I plan on tracing the wires to my speedometer an other gauges The car does have a computer (as in the one that gm/chevy provides. not a pc) has anyone traced these out and written a program or something similar im assuming if i get the readout on the gauges eg fuel ..... 5volts=empty and 10 volts=full etc... i could make a decent program if it hasnt been done in the past..
    only problem im not a programmer. ive dont some stuff cgi flash actionscript but never vb or c++
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    You can get some data in and out of the chevy computers of that era. There should be a connector under the dash, where you short two pins to flash the codes which has a another pin which is the data line.
      any idea what type speed oil pres etc? i was considering just soldering to the terminals that go to the actual speedometer would that work?
      .______
      | '_ |__\___
      [(o)|___(o)] XB
      ._________
      | I__I I_I|_\__I
      CarPCNetwork
        Its been a few years since I started researching that so I don't remember, but I know the pinout and protocol is documented on the internet somewhere.
          ill have to check then
          .______
          | '_ |__\___
          [(o)|___(o)] XB
          ._________
          | I__I I_I|_\__I
          CarPCNetwork
            wow.. i wanna do this.... 1994 dodge stealth. obd2 or 1?
            When in doubt, moo at things.
              where can I find that software?
              Did a And could not find any freebies for obd1 scan. anyone point me to the right place?
              CarPc Done.
              HA HA......Is it ever done?
                Never mind, found it. thanks anyway http://www.andywhittaker.com/ecu/screen_shots.htm
                CarPc Done.
