Rover Turbo
  • Rover Turbo
    Hi All I Have Rover 600 Ti (turbo 220bhp) Made In 1997 Does Any One Know If It Can Be Pluged In .
    I Think It Should Be The Same As Honda's System
    AND IF IT DOES IS IT POSSIBLE TO CONTROL THE TURBO PSI OUTPUT ?
    THANKS
    Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall return
    The car
    THANKS
    It is made after '96 when it was mandatory in America, so in all probability, yes. For the psi? don't know - you would have to find a spec sheet for its individual interface.
    steven n
    95 Saturn SC1
    Alpine 9831 + Blaupunkt SR04
    Stereo Integrity 327 Comps + MTX 4244
    Resonant Engineering XXX 18 D2 + Elemental Designs Nine.1 + 7.5ft^3 tuned to ~29Hz
    Carputer Progress: Rethinking, box has consumed my trunk
      Hi Skydiver... I have a 95 230bhp Vitesse ;-)
      As far as I know there is no way of plugging the ECU into a PC, unless your a Rover Dealer and then the program only reads fault codes...
      I've looked all over and even on Rovertech.net they say its not possible without a lot of investment. Cheaper to buy a new ECU with OBDII output.
      Do you have a CarPC setup yet?
      John
      My Nissan 200SX @ Silverstone
      NOW SADLY WRITTEN OFF!
      My Car's spec list + pics
      Stealth CarPC fab'ing...
        hi vitesse .
        pc not finished yet i have
        Globalsat BU-303 USB GPS
        Lilliput 7" Touchscreen
        1ghz dell optiplex form factor
        Mediaengine & WinXP Pro.
        destinator3
        few more weeks left
        The car
          <<<< another vitesse turbo owner
          Welcome to the club Skydiver (and hi again John )
          Your further along than I am on the build, well done, I hope to have mine in by springtime latest.
            thanks Mad Ad nice to be here
            The car
