OBD2 PIC code.
  • OBD2 PIC code.
    Hi,
    Besides the car tuner I have another self therapy which is building OBD2 interfaces
    I have a straight one (what goes in comes out) which I use for uploading SW on my car. This works ok.
    But my problem starts with my other interface based on a PIC and looks like a diet version of the one from http://www.obddiagnostics.com/.
    Now my confusion is all about the initialization with the ECU. Using the uploading SW it starts with pulling the K-line to ground and waits for reply.
    But if I read the ISO-9141 and other documentation I see that you first need to send a 0x33 and wait for response. So here I'm a bit confused. Second is the speed, 0x33 at 5 baud and then switch to 10400 baud, how is this done best with the PIC. The 0x33 on 5 baud is not a problem but the 10400 is a question mark. So does anyone have an idea or an example code maybe for the pic...
    thx rogier
    Professionals built the Titanic, an amateur built the Ark.
    It's variable speed in the initialization? I assumed it was 4800bps constant.
    Chrysler 300 - Fabricating
    http://hallert.net/
      no he is correct, it's 5 then 10400
      肚子笑痛了
      S60 Install
        I thought I had some example code hanging around here somewhere, but this and this might help you get started. PM if you have any questions.
        肚子笑痛了
        S60 Install
