Obd 1
  • Obd 1
    hey awesome site, just what i have been looking for.
    i've put the engine from a 1989 buick le sabre (3.8 V6) into my kit car. i am currently in the process of building a computer for the car. i will transfer the diagnostic plug and would like to monitor as many gauges as i can on the computer screen (15" non touchscreen LCD).
    i am also currently fabricating a new dashboard and would like to eliminate as many gauges as i can. i would ideally want only the tachometer and have fuel, oil pressure, voltage, and whatever else i can display on the screen.
    what data can i receive from the OBD 1 harness?
    i think there were only 3 or 4 wires connected to the harness.
    since my fuel guage is in the gas tank and does not go to the computer, is there a way to input the fuel level to the computer via another serial, usb or any other kind of input?
    thanks,
    rob
    Man oh man, if you find out the answers to this you will be my hero!! I have been looking for the same thing, but have come up blank. Good luck!
    VIA MII 10000 - 512MB Ram - Dual 2.5" drives, Xenarc 700TSV, Panasonic CW-8132-B, Opus 150, Audigy 2 NX, PowerMate, IOADR1610 10 Relay card
      There is a lot of info about this out there. A quick Google search on OBD1 or ALDL will yield what you are looking for. The place I got my cable has a boatload of links which point to free software for your laptop as well as trouble codes. Try www.aldlcable.com as a place to get started, but you can go from there to just about all the info you need. It is also a pretty good how-to for getting started.
