obd2 edit gm
  • obd2 edit gm
    Hey guys new to the site, and quick question, i tried a search but didnt hit it exactly.
    I have a 97 lt1 from a vette in my camaro its obd2, im building a carputer now and i was wondering what software is outthere that will let me see all the sensors and gages along with letting me edit the actual PCM(timing/O2/egr/open-closedloop/fan turn on-off/fuel-air ratios/lean-rich curves/etc.). and could i add things to it like F/A gages/ boost/ tranny temps/rearend temps/ etc. also is any of the editing software "realtime" i know on my older obd1 to edit the ecm i had to pop out the proms and flash tehm everytime i wanted to make a change. thanks in advance for the help i hope this isnt a repost
    ps. is there a frointend that can incorporate this? was thinkin of using centrafuse. thanks again
    i have the exact same question
    -Ross
    02 Camaro SS
    Opus 150W($150 used) Morex Venus 668 Case($109) Epia M10k($166) 128 Megs ($0), Maxtor 200Gig($76) CD-R/DVD($29) Lilliput 7"($285) Buffalo Airstation($42) Holux GPS($53) GM10-AUX(audio input, $72)
    Tot: $983
    Buying stereo!
      They are not real time adjustable with out external hardware. It still gets flashed but through the ALDL. The ELM interface will give you some info but I think only the generis PIDs nothing vehicle specific.
      The Car 2005 Scion xB
      The Truck 2004 GMC Canyon
        so what about some software to display these generic pids in gauge form?
        -Ross
        02 Camaro SS
        Tot: $983
        Buying stereo!
          Like this?
          Autotap will do it
          or here for more screen shots
            Will autotap work with the boards and cables from Digimoto?
            Dual Lilliput's 70NP/C/T
            Syntax SV266AD KT266A
            AMD Athlon XP 2000
            Viking 256MB DDR
            D-Link Wireless 802.11B
            Seagate 120GB
            OrbitMicro 250W DC/DC converter
            SII Wireless Audio Link
            Digimoto OBD-II
            Earthmate GPS
            BU-303 USB GPS
            D-Link Bluetooth
              HPTuners is exactly what you are looking for. You can display up to 24 PIDs at once and make some adjustments on the fly. However, the adjustments you make are temporary. In order to finalize a tune, you have to read the PCM, edit the file, then reflash the PCM.
              BTW, Autotap will only allow you to monitor your car and not make any changes to the tune. I'm selling mine if you're interested.
