OBD-II Problems
  • OBD-II Problems
    i'm sorry if someone as already ask this question...
    i know something about the car chip tuning and i know that if something happens while you are writing the code on the chip, somatimes you have to change it. so i'm asking if is it dangerous to keep connected the pc to the OBD port (and so to the chip) while the car is moving... ??? can if have problems?
    thanks, Chicco
    Well, the OBDII software here doens't write anything.
    PowerVoice v1 | NaviVoice Source
    GammaControl v2.4
    SKINbedder v3
    1995 Lexus SC300
      well, i know that it doesn't write anything, but if i send a wrong OBD message request is not a problem? and if the pc switches off during the connection is it dangerous?
        It shouldn't be dangerous. Isn't the car's ECU write once anyways?
        GammaControl v2.4
        SKINbedder v3
        1995 Lexus SC300
          it depends from the chip model... the olders were Read Only, but the last are EPROM (Erasable Programmable ROM) or Flash ROMS...
            Then figure out which type your car has
            GammaControl v2.4
            SKINbedder v3
            1995 Lexus SC300
              I posted this on the Regal forum, may be of use to y'all:
              http://www.regalgs.org/forum/viewtopic.php?t=20477
              Chrysler 300 - Fabricating
              http://hallert.net/
                interesting, thanks!
