ECU Emulator...
  • ECU Emulator...
    Does anyone know of an ECU emulator that is not dependant on any particular interface and can change ODBII porotcols (I searched this forum and found the JElmEmulator but I use the Multiplex-Engineering Interface).
    I would like this emulator to be able to able to switch protocols so I can test automatic protocol recognition on the scantool I am creating.
    The Emulator should have the 16 pin D connector just like the vehicle so I can perform acurate tests....
    I also need this emulator so I dont destroy my one and only car
    Thanks in advance.
    I think www.obd2.com might have one
