2005 Volvo S40
  • 2005 Volvo S40
    Is this the ODB-II connector? The picture right below the steering wheel on the left.
    If so, anyone know what protocal it uses? I read about checking the pins but Im not sure which pin is #1,#2 etc.
    bump, anyone? :-\
      yes!
      Time displayed in a different way!
      http://www.lares.dti.ne.jp/%7Eyugo/s.../03/index.html
      http://www.humanclock.com/
      FREE 3D Glasses: http://www.rainbowsymphony.com/freestuff.html
        looks like it
        肚子笑痛了
        S60 Install
          It's same with eu ford models... u may use that convertor kit. I already use it..
          http://www.ozenelektronik.com/index2.php
          '06 C-Max Worklog
            The communication protocol is
            ISO 15765-4 29 bit adressing for CAN.
            You may need a CAN bus adapter depending on the hardware you use.
            Krille
            Forgot to attach pin description, see picture below.
              Thanks guys!
