peugeot Sensor
  • peugeot Sensor
    Hi guys
    I really like the idea of attaching my car to the computer, The only problem is that i don't know what to use.
    The plug on my car is only a 2 pin plug so i am unsure what conectors are needed i spoke to peugeot and they assured me that they connect via this plug and use a diag 2000 to read the ecu.
    If anyone has any info on how i can connect this to my computer it'd be great.
    {[I][I][I][I][I][I][I][I][I][I]} 20%
    http://digimoto.com/confirmedobd.htm#peugeot
    That's a list of cars that are OBD-II and compatible with the ELMscan interface. (and for that matter, probably any other of the OBDII interfaces)
    that site lists the peugot 106, 206, and 406 as being ISO format, so presumably the 306 is also. You can find lots of different OBDII interfaces that work with ISO format.
    But don't take it from me! here's a quote from a real, live newbie:
    Originally posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
      The 306 is if a 2000 model or newer, anything older and I wouldn't bother looking as they do not push out standard codes.
        yeh it's a 94
          you're screwed then. like me
          oh well, got enough things to build withotu a system that shows me just how bad my engine is running!
