Building OBD-II Controller
  • Building OBD-II Controller
    I have done some research ( )on this, and have a circuit diagram but which chip do I use. The ELM323SM or the ELM323P? Short easy question.
    1998 Honda Accord LEV
    [-|-------------] Planning Stage
    www.kiwiwebsite.com
    forum.studiofenix.com
    Do you know how/wish to undertake surface mount ->SM. If not, P.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
      I dont really understand that so could you explain it to me? Is the actually any difference in the two besides this surface mount?
      www.kiwiwebsite.com
        Surface mount chips are the tiny little ones with almost no "legs" to them. They require special equipment (mainly a toaster oven, and special solder). You also need some amount of skill in placing the components.
        Other then the surface mounting, and the related size difference, there is no difference in the chip.
        Oh, and the Surface mount type wil absolutely require a printed circuit board. I don't think there is a way to do it otherwise. I don't know how you are doing it, so I thought I might throw that in there.
        2000 Subaru OBS
        Dell P3 @ 900 Mhz
        80GB External HD
