Nissan computer interface system
  • Nissan computer interface system
    what do you think about this?:
    http://www.blazt.biz/
    isnt it too much expensive?
    seems so simple...
    that doesn't look too steep...and it seems to be manufacturer specific, not universal so you'll probably get more feedback out of it.
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
      its not the consult program but looks better tahn the br-3 i'm using now. I wonder if some of the reading is done with the software end. I'll download and test it.
      Live mp3Car Facebook Chat
        Well i couldnt find that program for free but a couple of google searches landed me on a scantech program. Check out the gauge screenshot. It works with multiple interfaces and is generic OBD-II. Here's the link http://techdiag.co.uk/obdscantech/ScanTechProject.rar
          Try Nissan Datascan 1.52. It has some nice guages
          And there is a new release of ECUTalk out
          My Nissan 200SX @ Silverstone
          NOW SADLY WRITTEN OFF!
          My Car's spec list + pics
          Stealth CarPC fab'ing...
            Originally posted by ShawJohn
            Try Nissan Datascan 1.4. It has some nice guages
            That's what you get with the Blazt interface... for others look here...
            Old setup
            Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
            New setup
            Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
            Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
              well i tested the scantech one and its pretty decent. Gauges are better than br-3 software, it worked (kinda) with the br-3 interface and finally i can see MPG! It wouldnt use it as the primary obd reader cause it has communication issues with my br-3 but at least it worked at all.
                The BR-3 software is an OBD-II scan tool program whereas datascan etc are consult...there's also a russian program called vcons, I haven't tried it with my PMLS interface yet though. It's all in Russian too.....
                Old setup
                New setup
                  shame it needs 1024x768 cause most EPIA carPC's are now able to run 800x480
                    yea the program i tested was TRUE 800x600. Small portion is outside the range of my lilli
                      For G35, 350Z, Titan, and Altima SE-R you might like to check out Cipher GB or http://www.uprev.com
                        ecutalk will resize to any screen size, including widescreen. also has pocket pc version. also free
                          conzult is free along with many others. You just need a consult to laptop cable and you are set. PLMS and a few others make one. There are instructions all over on how to make your own.
                          Brent
                          1999 Nissan SE-L - turbo toy
                          1993 Nissan NX - Turbo Racer
                          Standalone fuel management (AEM EMS) on both
                          carPC
                            Here are some great sources of info for various Nissans. Not sure if your car is OBD I or II since nissan sold both during the 1997. (at least in North America)
                            Data Scan
                            Biki Rom
                            300 Degree
                            PLMS Developments
                            CalumSult
                            OBD Scan Tech
                            Nissan Club
                            Daughterboard Writeup
                            This should get you started. Ive found through looking around that about $100 to $130 is the average for the hardware and software combos.
                            Osiris Networx
                            --Tuning is all about price vs performance. You've got to find your own medium.--
                              Calum is a good friend of mine, he has posted up all the info you need to make a PC cable/Consult port scanner. I recommend that for sure.
                              PLMS would be my second choice as it is simple, they did all the work!
                              Brent
                              carPC
