My ELM323 only works with 'ScanTool'
  • My ELM323 only works with 'ScanTool'
    Hello,
    I recently finished making my own ELM323 OBD interface and only 1 software application that I found (ScanTool) works with my laptop, and to make things worse less than half of the parameters are available. Any other software app that I tried does not even see the interface (Car-code/Pro-scan etc).
    Has anybody any ideas what is going wrong?
    that is odd. supposively there are plenty of third party software programs that will work with the ELM chip. from what i gathered, its simply just a serial interface. something maybe wrong with your setup possibly?
      the same for me
      Originally posted by ren_laguna
      Hello,
      Hi at first i by digimoto kit and it was suppose to work on Volvo and it not after contac digimoto they told me to try scan tool.net and it work ! for the parameter it's the same , maybe digimoto whil work for you .
        I made the cuircuit from the ELM schematics, and it does the exact same thing with other EOBD/OBDII cars.
        I have double checked the ciurcuit a few times and all is perfect (its squashed onto a PCB 2/3rd's the size of a matchbox), I am going to rebuild another larger PCB and try again.
        In the meantime I will try digimoto.
        Thanks for your help!
          there is a free version of Digimoto called lite
          it works with the elm chip go to their website and download it for free,
          http://www.digimoto.com/updates.htm
            Since the release of Digimoto 4.03 we have cleared up many issues regarding integration with the Volvo line. If you have any questions regarding integration with your specific type of vehicle you can always e-mail me (joel@digimoto.com) or call me (414.232.6121) directly.
            Joel Konecny
            Digimoto OBDII Diagnostics
              ELM 323 programs
              Digimoto Lite
              EasyObd II 2005 Version 1.0 by EasyObdII.com - Steve Duddridge
              GM Mode 22 Scan Tool by Terry
              OBD Gauge for PalmOS and Pocket PC by Dana Peters
              OBD Logger by Jonathan Senkerik
              OBD-II ScanMaster by Wladimir Gurskij
              obd2crazy.com
              OBD2 Scantool by Ivan Andrewjeski
              OBDII for ELM322 by David Huffman
              pyOBD by Donour Sizemore for MacOSX and Linux
              RDDTC for the PocketPC byPete Calinski
              Real Scan by Brent Harris
              ScanTest for Pocket PC by Ivan Ganev aka a-ser
              Servertec ScanTool Communications Gateway (Java)
              wOBD by WDT
              Non-free software:
              Note that some software vendors offer feature- or time-limited versions of their programs.
              Digimoto
              ElmOScan
              OBD2Spy
              PCMSCAN
              ProScan
              SoftDavid (in Spanish)
              VitalScan
              I have tried most of them, I do have all the links but i do not know how to add a HTML post.
              email me if you want all the links, or you could use google.
              shoulder
              www.lancastrian-it.co.uk
                Hi,
                Friend I have buy recently interface for ELM323 where can I downalod software which will work with my interface
                Many Thanks
                  Elm323
                  Hi,
                  Many Thanks
                    ELM software
                    Hi,
                    here is a list and www links for all ELM 323 and ELM 327 OBDII interface software.
                    Sorry it took so long, didn't know how to upload the page.
                    just download the rar.
                    shoulders
                      I have the exact same problem as you. Does your connector cable say "ODB Diagnostic Interface, Supports all ODBII Protocols" on it, and is it orange and purple? I think you might have the same as the one I got. I bought this horrible OBD2 connector for almost nothing on eBay, and now the only program that can communicate with it is a crippleware demo version of "ScanTool, some crappy shareware program that was written around the era of Windows 3.11 (I'm serious; it's really from the early 90's.)
                      I have tried ODBSpy, Scanmaster ELM, and OBD-Diag, and none of them can recognize it.
                      I wonder if I have the wrong driver installed on my laptop? Because this thing is supposed to connect on some sort of "serial usb" connection, and my laptop doesn't show any serial ports, so I wonder if it's really properly connected. Does anyone have any info on this?
