Mode $06 revealed - Why is it such secret?
  • Mode $06 revealed - Why is it such secret?
    Why is it sooo hard to find information about mode $06 (mode six, mode 6)? Almost every hit on google is some guy selling his "secret" information that'll "unleash the power of OBDII Mode $06!!!"
    Well, after poking around a bit, I've figured it out I think. I got an OBD2 All-in-one scanner (ELM327 based) recently, and have been playing around with it. This lets you manually send data to the OBDII bus. Using this and the Honda mode $06 documents from https://techinfo.honda.com/rjanisis/RJAAI001_mode.asp, I was able to determine the following.
    This is what I sent in hyperterminal (this is all in hexadecimal):
    Code:
    06 21
    06 - indicate this is a mode $06 request
    21 - request parameter identification (PID) code 21
    (and for mode 6, PID is equivalent to test identification (TID))
    The response:
    Code:
    46 21 81 00 09 00 04
    4 - indicates this is a response
    6 - to a mode 6 request
    21 - for PID 21 (i.e. TID 21)
    81 - indicates this is a result from component ID (CID) 1, and the test limit here is a lower limit
    00 - padding? used for larger values?
    09 - test value
    04 - test limit
    One value needs more explanation, that value 81. This is one byte, and can range from $00 to $ff. The first bit, or most significant bit (MSB), indicates whether the test limit given is a lower limit (bit=1) or upper limit (bit=0). The lower 7 bits indicate the component ID (CID). So in this case, $81=0b10000001 in binary, the top bit is 1 so this limit is a lower limit, and the lower 7 bits indicate this is a CID of 1.
    So, we open up the mode 6 doc for the 1998 Honda Civic, and you find the following:
    For a TID of $21 and CID of $01, they tell you the following:
    Monitoring the fluctuation of fuel tank pressure sensor output before and after
    EVAP bypass solenoid value is opened after engine starting with cold condition.
    Measured value: Output value (Decimal) x 0.488281 (mmHg)
    The lowest limit value: Output value (Decimal) x 0.488281 (mmHg)
    So our test result was 9, which when multiplied by their conversion factor gives 4.394529 mmHg, compared to a lower limit of 1.953124 mmHg. Which means, we passed the test, which is why the CEL/MIL lamp hasn't gone off. If the value reported was below the lower limit, then according to the mode 6 doc, a P1456 code would be issued and the CEL/MIL lamp would come on.
    So, what do you all think of this? Is this right? It only took me an hour or so of tinkering around to figure it out. Why is it made to be such a secret?
    If you look at a more recent model year, you'll find there are A LOT more tests that you can lookup. The mode 6 doc for the 2006 Hondas is 37 pages long, with all kinds of different tests, like finding out the number of times a cylinder misfired.
    1998 Honda Civic LX
    In VERY early planning stages now
    Awesome avatar from DannyWork@Flickr
    i think all information like this is meant to be a secret, people want to make money off of you any way they can. thats why it costs tons of money to buy specification licenses. Very cool, are you a programmer? Are you going to work on this any more. Also is this specifically honda?
    PC Components:
    My work log
      Mode $06 is part of the OBDII specification, so it is not Honda specific. It seems though that it is only available on 1997 and newer models. However, the number and type of tests available is specific to each make and model. Since the computer only gives you bytes of data, you need the data sheets for mode $06 from the manufacturer. techinfo.honda.com has all the Honda and Acura sheets, and I believe most of the other manufacturers have similar sheets available on their sites.
      I'm not full-time, but I am a hobby programmer. I'm also a big promoter of open source, and there aren't any very good open source OBDII scan program out there now, in my opinion. Like I've mentioned in other threads, I'd like to write a complete, cross-platform OBDII scan program for the ELM series of scanners, but make it modular enough so that others could add support for their own scanners in.
      1998 Honda Civic LX
        Mode $06 isn't really a secret. More likely you're experiencing a disorganized website. If you go to service.gm.com they have a Service Information tab with the identification and scaling clearly posted. Ford provides their information upon request to scantool vendors.
        Unfortunately other OEMs don't play nice. Notice http://www.etools.org/i4a/pages/index.cfm?pageid=2407 which says Honda refused to provide their data to ETI, and tries to charge $5000 per year for scantool information.
          I found the GM site in my searches, but even there it doesn't tell you how to dissect the response, i.e. byte three indicates test limit type and component id, bytes 4&5 are the test value, and bytes 6&7 are the limit value. I couldn't find a single mention of this anywhere in my search. Those GM pdfs were the only way I figured out how to decipher byte 3.
          I don't claim to have made some breakthrough, or that it took a lot of effort. I'm just surprised that I couldn't find a single mention of how to decipher the mode 6 response, other than that bit from the GM pdfs.
          Hmm, it seems Honda has the same information GM has on techinfo.honda.com site.
          1998 Honda Civic LX
            Where to get description of OBDII ( Mode06) codes
            for Chrysler Intrepid 2002
            jma
              This thread came up on another search I was doing for ETI - that link Joey had is now invalid.
              This seems to be the same info for Ford:
              [media]http://www.motorcraftservice.com/vdirs/diagnostics/pdf/OBDSM701.pdf[/media]
              Lukeyson
                Chrysler OBDII Mode $06
                TID 16 O2
                TID 17 O2
                TID 26 O2
                TID 27 O2
                TID 28 O2 Heater
                TID 29 O2 Heater
                TID 2A O2 Heater
                TID 2B O2 Heater
                TID 2C O2 Heater
                TID 2D O2 Heater
                TID 2E O2 Heater
                TID 2F O2 Heater
                TID 36 O2
                TID 37 O2
                TID 3D Catalyst
                TID 3E Catalyst
                TID 55 EGR
                TID 56 EGR
                TID 57 EGR
                TID 58 EGR
                TID 59 EGR
                TID 5A EGR
                TID 5B EVAP
                TID 5C EVAP
                TID 71 EVAP
                TID 72 EVAP
                TID 73 EVAP
                TID 74 EVAP
                TID 75 EVAP
                TID 76 EVAP
                TID 77 EVAP
                  Graet Topic, please help Interepret for Corolla 2000
                  Corolla 2000, 97000 miles
                  The manual recommends test $06 $02 for 2004 which I did and here is the result
                  >0602
                  46 02 81 00 75 00 4C
                  According to manual
                  $81(Tank pressure change value during Vacuum introduction), Malfunction criteria for VSV for EVAP , Units = mmHg, Multiply by0.0916
                  So, does that mean the EVAP VSV is faulty?
                  But this is not a failed case as 81 is the lower limit and value $75 > $4C right?
                  I have the relevant pages uploaded. Then why do I keep getting P0441, if no fail?
                  P0441 (With $06 $02 monitor info)
                  How to use Monitor page.
                  Separately does corolla 200 have no freeze frame storage? I do not see any freeze frame data and $02 $00 will return NO DATA for P0171 and P0441. Any Ideas?
                    I see answers here for a 06 xx under the pre CAN modes newer cars respond
                    a bit differently for a testID Request
                    with an ELM interface with CAN format I get the info below can somebody help me
                    translate it???
                    I query 06 01
                    and I get
                    049
                    0: 46 01 01 0A 0F C7
                    1: 0F C7 0F C7 01 02 0A
                    2: 0F C7 0F C7 0F C7 01
                    3: 03 0A 09 9C 09 9C 09
                    4: 9C 01 04 0A 11 9E 11
                    5: 9E 11 9E 01 05 10 00
                    6: 23 00 00 00 F9 01 06
                    7: 10 00 15 00 00 00 62
                    8: 01 80 2B 00 7A 00 2F
                    9: FF FF 01 81 2B 00 79
                    A: 00 2F FF FF AA AA AA
                    My guess is that I have 049(hex) bytes to look at 5 bytes per CId???
                    do I start after 46 01 01 or after 46 01???
                    Cheers
                      Open Source and Mode 6
                      I believe in the open source methods too. I'm just finishing an OBD2 interface based on Excel/VBA, that uses any generic device with the ELM327 protocol (doesn't necessarily need to be the ELM327). The good thing about Excel you have complete flexibility in expanding or modifying the app. Any one with basic skills (programmers or not) can modify and enhance it. I am planning to post it here when I'm able to, and see if there's any interest. I'm not a big fan of Windows for real time processing, but it basically works well enough, and it is such a widely used app that most everyone already has installed on the PC. As to the mode 6, I was wondering about the "secrets" of this too, and thanks to everyone's comments above, I added a page to the obd2VBA app that displays the mode 6 results. Thanks!
