Egt
  • Egt
    Has anyone found or made an interface to take the output of an exhaust temp probe & feed it into the computer? PCMSCAN says their software can display exhaust gas temps (EGT) but I need the hardware presumably analog to digital to plug the probe into my carputer.
    Here is a USB Phidgets Thermocouple that might do the trick. Up to 1200C, so should handle EGT.
      Thanks for the info, but EGTs can go as high as 1800°F. I have a probe already (it came from a EGT gauge), I just need the interface to the computer.
        By the way... 1200°C = 2192°F
        Just FYI..
          My bad, I should of caught that. I'm not used to dealing with metric temps.
