different cables different sensor readings?
  • different cables different sensor readings?
    My buddy has an ELM327 cable that he uses with digimoto 4.03 and Proscan 4.0. When hooking it up to my 1997 Chevy K2500HD 6.5 Turbo Diesel L65 Vin F, it only reads 6 sensors in any program we try. It reads IAT, VSS, RPM, LOAD, ECT and MAF(even though it has no MAF sensor). The reading I want is MAP (for boost). I have a boost gauge so I know what I'm getting, but I use a boost fooler on the boost sensor so I can run higher boost.
    Anyway, will different interfaces acquire different sensor readouts? I'd love to find one for boost.
    If I understand correctly, it's all dependent on the protocol the auto manufacturer uses for OBD and whether they implement any custom codes in that protocol.
    I'm not the expert, mind you. I hope someone who knows more than I chimes in and corrects me if I'm wrong.
    How about the Wiki?
      The intelligence is really in the software. Although a different cable might read faster or slower, there will be no difference in the data. Although I don't have information on the 97 K2500, I can provide a few ideas for you to consider.
      OBD-II reports a a list of supported parameters. Some vehicles lie -- they might claim to support a parameter (but it's not available) and vice versa. If your scantool software relies upon this report, you might try to override and ask for MAP anyway.
      DP has a great point about the manufacturer-specific data. OBD-II has a standard parameter (0x0B) available for Intake Manifold Absolute Pressure with a range 0-255kPa and resolution of 1kPa, but Chevy might only report MAP with a manufacturer specific request. As far as I know, Digimoto and Proscan only request generic parameters. See if you can find GM specific software that has a more complete parameter database.
      Also it's possible that your engine controller has buggy software or does something unusual. Is your engine calibration up-to-date? Are they reporting MAP in place of MAF? Is the value a reasonable estimate or conversion?
      Finally, 1997 is only the second year that OBD-II was required. Your model year might provide a very limited number of parameters. You might simply be stuck!
        its a factory computer, so i have no idea if its been changed or messed with. Although there is a MAF reading available it always reads 0. With PCMSCAN I have had it do an 'aggressive' search for 'hidden' parameters and it only found there reported ones.
        I'll try again and see if I can force the 0x0B.
        thx
