Ecu Files
  • Ecu Files
    hi i have just brought the kwp2000 hardware i have recived a cd which contains crap i think i neen TUN files these are the only files that the kwp 2000 software reconisis does anyone know where i could buy or download these files from i do have some MOD, ORI files does anyone know what ii ahev to do to them thanx
    The first thing you have to do is turn on the spellchecker on your computer.
      This may not be the right forum to be asking about ECU images...
      Tidder
      Try RevFE
        Buying an ECU image file over the Internet is just plain stupid. You risk blowing the engine at worst or just getting poorer performance / killing fuel economy at best.
        The only way to tune a modified engine (and it it ain't modded then forget an ECU image cos it won't give you anything that you can feel) is to run it on a rolling road and have the ECU mapped for peak performance for your particular engine - that covers Ignition advance curves, fuel maps, load variables, temp variables and if you have an electronic gearbox then the solenoid shifts etc.
        Burning your own map without fully understanding the mods that have been done to your engine and how they all relate to each other is going to be an expensive lesson learned (yes, I learned it the hard way!)
        RV : Samsung Q1 + Kyocera KR1 (EVDO) + GPS<br>
        Car: AMD 3000+ Book PC + Lilliput 8" Touch + 13" TFT
        Webmaster for the European Ford Scorpio Site
          (Except for the point on tuning a mostly stock car, not always worthless)
          GE Cache Builder | [email protected] |Coolstuff :autospeed.com | bit-tech.net | Nitemax Ultra Pinouts
            yes i also learned the hard way!!!!!
              please help me! files for vw passat 1.9tdi pd 96kw
              Does anyone have or sold tuning files from kwp2000 for the ecu nr: bosch 0281010941
              Thanks in advance and i apreciate any answer
                no advance?nobody shares or sells tuned ECU files??
                  What car is it? passat 1.9 130hp 4motion?
                  You can buy it here: http://www.cth.be/shop/tuning_tabel....30&fuel=diesel
                  before you buy it ask for dyno results...
                    Which is the best ECU flasher i can buy
                      The best one for the price is the eobd 12.50 galletto .
                      It does the most models including edc16, which a kwp2000 won't flash.
                      As for using tuned files from the suplied dvd, don't do it. Most of those files are just plain dangerous to the health of your car and wallet.
                      If you are looking for original ecu files to restore your badly flashed ecu to normal status you can download a bunch in www.chiptuners.org forums for free.
                        mapping
                        ori files are the orignal manufacturer map on the ecu, mod is a tuned file galetto tool is only good for bmw and even then it sometimes goes wrong as after using it to write a file it does not close the ecu lol! hope that helps. if u try to mod maps urself without knowing what u are changing u will cause some damage to the engine because there are so many different maps on there like gear change, rev limit, ignition timing, air fuel ratio! also if u buy cheap maps from the internet u can kill the ecu.
                          ecu files
                          i found 55.000 ecu tuning files on ebay.
                          the price was about 30 euro.
                          greetings
                          marcel
                            vw bora 130 tdi pd
                            ive go a map for yours i had mine done few years ago ive copied it and used it
