software? or just me being stupid?
  • software? or just me being stupid?
    j
    You need more than just the cable that physically connects the obd1/2 ? to the serial or usb port of the computer. Search a little bit, and you'll see what you are missing.
    Unfourtantely some of our servers are down at work and i'm having trouble searching for anything right now
    REBUILDING!!
      thought aldl was gm only?
      Core duo
      1tb harddrive
      256 ddr
      8 lilliput
      bu-353
      still installing...
        notice that big piece after the obd2 connector? Do you have something like this?
        REBUILDING!!
          i declare this thread dead, please no more posts, in here as i dont care anymore, have a buddy that just came in to town that can fix it
            Lol, good luck
            REBUILDING!!
              yea i think a picture of what you had would of helped.
              haha
              Core duo
              1tb harddrive
              256 ddr
              8 lilliput
              bu-353
              still installing...
                the cable:
                ALDL Cable w/OBD2, USB Version
                This cable is for 1994 and 1995 OBD1 cars equipped with the 16 pin OBD2 style connector (Camaros, Firebirds, Corvettes, and LT1 equipped cars are a few), and has a 16 pin OBD2 connector shell to plug in under your car's dash to interface to your car's ECM/PCM. This cable is the most convenient to use if your car is equipped with the 16 pin connector style, as it allows you to just feel under the dash to plug it in. See our home page for references and diagrams of the connector styles, or see the OBD2 diagram below. Please check under your 94-95 car's dash and make sure it has the 16 pin style connector before ordering this cable.
                  You don't, just that cable won't work.
                  REBUILDING!!
                    ok so its just aldl with a different connector.
                    which means gm only i think.
                    so is your car on the list
                    http://winaldl.joby.se/aldldata.htm
                    cuz then that program should work
                    Core duo
                    1tb harddrive
                    256 ddr
                    8 lilliput
                    bu-353
                    still installing...
                      the cable he showed us is obd 2 cable for obd 2 system, i have obd 2 connector and obd 1 system, i know its not obd 2 system since i asked a mechanic when it was in for service,
                      84RegalRider, didnt understand the list too good, but i dont think its in there, but it said that the list was not complete, so it may or may not be listed there,
