Is there OBD Connector in my Car?
  • Is there OBD Connector in my Car?
    My car is Hyundai Elantra with a-CVVT engin,Made in 2006.Is there OBD connector in it?and How can I know where it is?
    Could somebody take some photos?
    Hi,
    You will have an OBD2 connector, it has to be within 2 foot of the steering wheel, and easily accessible. They are often covered with a clip off cover, or could be under the dashboard - have a nose about. You are looking for a rectangular plug that looks like this.
    Being 2006 you need to also bear in mind that your car is also probably using the CAN protocol.
    Good Luck!
    Gareth
      Yup, you have one. All above '96 (I think) have it. Must be within a meter of the steering column like UKOBD said. Sometimes you must remove a few panels to get there, but it should be "easily accessable" as per the standard.
      1.9in x 2.9in -- 47mm x 73mm
        How to analyze OBD msg ?
        Hi,
        Can someone tell me how do i analyze the OBD information recieved from ECU?
        I am using CAN interface and i need to analyse the different data (DTC, Freeze frame ..) and display the recieved information using display interface.
        So how do i analyse different types of data recieved from ECU ?
