Remapping ECU
  • Remapping ECU
    Hello,
    I bought DVD with 30000+ ECU tuned files. But there is no usefull program to open and write this files into car's ECU. Can you help me with name of good software for it.
    Which software can read/write (proably HEX) files into ECU over OBD-II interface.
    Thnx
    Hi,
    You are not going to find this possible over a generic-OBDII interface, and need to be exceptionally careful when making changes to the ECU.
    You need a pass-through type system, details of which are elsewhere within these forums.
    There is a lot of software around on eBay, etc. which is useless - I would recommend going to specialist if you are looking for a remap.
    Good Luck,
    Gareth
