Obd I
  • Obd I
    Can some one tell me plese, which product I should use, to make diagnose for calibras 1993 engine??
    You need a simple code reader for this ECU, you can just plug them in and they flash out the error code on an LED. We used to sell them a while back, but ran out months ago.
    I think they are still available in Halfords if you are UK based.
    Aside from that there is a DIY route, but you do need to be careful what pins you access - info is available all over the web, but have a look at http://astra.autokacik.pl/download/aldl.pdf for some hints.
    Good Luck!
    Hope this helps,
    Gareth
      yes I now, that i can conect some pins, and than lite will show, but I whanted to use some device!!!
      Maybe you can remember the name of it, so I can try to find it on ebay?
        Hi,
        It is a Gunson Tool, I found one on Google:
        http://www.toolsinstock.com/index.ph...roductId=14263
          thanks
