ELMscan Ford AU falcon (OZ)
  • ELMscan Ford AU falcon (OZ)
    Have been searching forums for ways to make this unit work with my AU2 XR8 falcon
    it has an OBD2 type connector - but I am unsure if it uses the std odb2 protocols
    With an NGS star diagnostic unit - I can get all the pids and also retirieve real time information - but borrowing it from work is a nightmare
    Does anyone know whether the elmscan5 will pull information all the information from the car.
    I can connect to it - using pcmscan but onlly 8 of 98 pids are identified
    If there is a config file to make this work - I am interested in knowing the details.
    I am trying to diagnose a problem with the car - prior to doing an edit to the ECU
    ANy information or help would be appreciated.
    BTW - the scantool v1.13 software does not recognise connection with the ecu - PCMscan seems to give some information - still trying other softwares - but i have the feeling it could be an obd1 with a odb2 interface on the car???? - stumped
    Will try the hyperterminal and see if I can get some detials re-connectivity of the elmscan device
    What do others use to get the pids?
    Thanks in advance
    O
    To be honest, I don't know what protocols are used on the AU. Only that the BA supports CAN and ISO.
    Sorry I couldn't be of more help. But it might be worth your while poking around www.fordforums.com.au or www.fordmods.com.
    Lukeyson
