Mode $06 question
  • Mode $06 question
    I understand that mode 6 is for 'non-continous test results' that the pcm stores after it has completed testing of involved components, but recently I found this that I am not quite sure what to make of it -
    http://www.aa1car.com/library/honda_mode06.pdf
    Its a list of test ids for mode $06 for honda. So when they say that for a 4cyl accord the test id for EGR flow is $03 and comp id is $81, how is that useful to someone who wants to query the egr flow ? How exactly do I interpret this table ? What command should I send to the interface ?
    I am using OBDPro, it that matters.
    Maybe this will help you get started: http://www.mp3car.com/vbulletin/showthread.php?t=75252
    Joel Konecny
    Digimoto OBDII Diagnostics
      thanks. that should definitely help me get started.
      I wonder why ignition timing is included in mode $01 as a generic real time sensor available to obd2, yet knock sensor is not available even in mode $06 components, since knock sensing influences timing and thereby emissions directly.
