New Release 0.6
  • New Release 0.6
    Hola all,
    I just released a new version, 0.6. I've pasted the salient ChangeLog section in below:
    Version 0.6 (released 2009-06-15)
    Move obdlogger source into its own subdir
    logger optimisation: remove all spaces in obd streams
    logger: add a serial port communications log
    logger: move capabilities into its own file, add features
    logger: Only create database columns, and only try to log, supported pids
    logger: add serial port logging option
    cmake: default gps dev [for ui] separately compile-time configurable
    logger: Dbus support, announce obd samples using SYSTEM dbus
    logger: reset elm device when we begin, and when we exit
    Add common "conf" library to read configuration common to all components
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
