ftdipty related build error
  • ftdipty related build error
    I tried building everything from trunk (r326) and got the following error at the end:
    Undefined symbols:
    "_ptsname_r", referenced from:
    _main in ftdipty.c.o
    ld: symbol(s) not found
    collect2: ld returned 1 exit status
    make[2]: *** [../bin/obdftdipty] Error 1
    make[1]: *** [src/ftdipty/CMakeFiles/obdftdipty.dir/all] Error 2
    make: *** [all] Error 2
    OS X 10.5.8 PPC Xcode tools 3.1.4
    I removed fdtipty from the build and everything else built and installed fine.
    Just informing you of the build error
    ... man, I even checked for that, but only in obdsim [not obdftdipty].
    Guess I've never compiled obdftdipty on OSX [oops]
    I've committed the fix. If you try it please let me know if it worked [no reason it shouldn't, but...]
    Thanks!
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
      Pulled r327, rebuilt and installed, everything compiled fine.
        Yay!
        Thanks for letting me know about the bug and checking the fix. Please don't hesitate to ask if you have any other questions, or success stories, or anything!
        Gary (-;
