Building OdbGpsLogger on Linux
  • Building OdbGpsLogger on Linux
    I'm trying to build on ubuntu linux 10.04 (lucid). But cmake is giving me this error:
    Code:
    -- Could NOT find FLTK  (missing:  FLTK_FLUID_EXECUTABLE)
    Here is the full output:
    Code:
    ~/projects/obd2/obdgpslogger/build$ cmake ..
    -- Found gps_stream method in GPSD - assuming version 3 API
    -- Found GPSD: /usr/lib/libgps.so,/usr/lib/libgps.so
    -- Couldn't find fluid: required for building GUI
    -- Couldn't find fltk: required for building GUI
    -- Found FFTW3: /usr/lib/./libfftw3.so
    -- Couldn't find fluid: required for building obdsim fltk gui
    -- Couldn't find fltk: required for building obdsim fltk gui
    -- Found dlopen. Building dlopen sim generator
    -- Found getaddrinfo. Building socket sim generator
    -- Found LIBFTDI: /usr/lib/./libftdi.so
    -- Configuring done
    -- Generating done
    I saw this: http://www.mp3car.com/vbulletin/obdi...gpslogger.html
    i think i have all the libs installed. When i run this apt-get says everything is installed.
    Code:
    sudo apt-get install libfltk1.1-dev libfltk1.1 fltk1.1-doc fluid
    I can run fluid from command line, i get the fluid gui.
    Any help for getting cmake to find fluid would be appreciated.
    I know i dont need the GUI, but it would be nice.
    After making sure it's all installed, you probably need to purge your build dir; cmake can occasionally be a bit overzealous on its caching. Just rm -rf build, and start again.
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
      Geeze, I dunno why i didnt think of deleting the dir.
      THANKS after starting cmake with a clean dir, everything works great.
        Yay!
        Gary (-;
