a few things
  • a few things
    Hello, I downloaded obdgpslogger yesterday and have spent some time getting it to work. I'm using Ubuntu 9.10, 32 bit, and an ELM32x compatible USB interface (supports ISO9141, CAN, SAE, J1850). I can get obdgpslogger to do a few things, but the behavior is not very predictable. Here is some output:
    $ obdgpslogger -t -s /dev/ttyACM0
    Opening serial port /dev/ttyACM0, this can take a while
    Successfully connected to serial port. Will log obd data
    Successfully connected to gpsd. Will log gps data
    Couldn't get obd bytes for cmd 00
    here
    Creating a new trip
    Introspection requested. Need to implement!
    $ obdgpslogger -p -s /dev/ttyACM0
    Your OBD Device claims to support PIDs:
    PID: [column] human_name
    00: [unknown] PIDs supported 00-20
    01: [dtc_cnt] Monitor status since DTCs cleared
    03: [fuelsys] Fuel system 1 and 2 status
    04: [load_pct] Calculated LOAD Value
    05: [temp] Engine Coolant Temperature
    06: [shrtft13] Short Term Fuel Trim - Bank 1,3
    07: [longft13] Long Term Fuel Trim - Bank 1,3
    0B: [map] Intake Manifold Absolute Pressure
    0C: [rpm] Engine RPM
    0D: [vss] Vehicle Speed Sensor
    0E: [sparkadv] Ignition Timing Advance for #1 Cylinder
    10: [maf] Air Flow Rate from Mass Air Flow Sensor
    11: [throttlepos] Absolute Throttle Position
    13: [o2sloc] Location of Oxygen Sensors
    14: [o2s11] Bank 1 - Sensor 1/Bank 1 - Sensor 1 Oxygen Sensor Output Voltage / Short Term Fuel Trim
    15: [o2s12] Bank 1 - Sensor 2/Bank 1 - Sensor 2 Oxygen Sensor Output Voltage / Short Term Fuel Trim
    1C: [obdsup] OBD requirements to which vehicle is designed
    here
    Creating a new trip
    The logger is generating a log, which I can read using obd2csv, but there is no obdII info included, even if I use the -i switch to list columns. Sometimes the -p switch works and sometimes it doesn't. Also, the -t switch doesn't seem to work.
    Any ideas?
    I'm always slightly afraid when things are inconsistent.
    That "-p" output looks right when it did work. Could you try creating a serial log a few times [--serial-log <file>], and see what you get when it works, and when it doesn't?
    What exactly is the device that you have? I've never tested with anything that wasn't an ELM327. I've also never seen anything create a /dev/ttyACM device before. Where did you get it from?
    My actual suspicion is that it's just a cheap chinese device that may just be not-entirely-functional [which wouldn't be unprecedented]. Are you able to open it and look inside? How is the main chip inside labelled? Does the circuit board look like it's properly soldered?
    Thanks,
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
      The device was purchased from a european company called Secons. It is nicely soldered and seems to be well constructed, though the plastic housing is stamped "Made in China", as you guessed . The main chip is a PIC18F2455.
      Here are 5 trials in a row. The command line, output and --serial-log output for each trial:
      1) doesn't work:
      $ obdgpslogger -p --serial-log new.txt -s /dev/ttyACM0
      ATZ^MATZ
      ELM327/ELM-USB v1.0 (c) SECONS Ltd.
      >^M
      >0100^MATE0^MBUSINIT: ...OK
      41 00 BE 3D B8 10
      >ATL0^MATE0
      OK
      >ATS0^MOK^M>0100^M?^M>ATZ
      2) does work:
      ATZ^M>?^M>^M?^M>0100^M41 00 BE 3D B8 10^M>ATE0^MOK^M>ATL0^MOK^M>ATS0^M?^M>0100^M^M41 00 BE 3D B8 10^M>ATZ
      3) doesn't work:
      ATZ^MATZ
      >^M
      41 00 BE 3D B8 10
      >ATL0^MATE0
      OK
      4) doesn't work:
      ATZ^M>^M?^M>0100^M?^M>ATE0^M41 00 BE 3D B8 10^M>ATL0^MOK^M>ATS0^MOK^M>0100^M?^M>ATZ
      5) does work:
