Molding clear parts
  • Molding clear parts
    This is not my thread, but I thought the how-to was nicely done and has some good information in it. I am not sure how many people want to make clear parts, but it is worth a look.
    http://forums.nasioc.com/forums/show....php?t=1236593
    hmmmmmmmmm, wonder if you could make a fiber glass mold of your car, then use this to make a clear molded sub box... or would it be no where near strong enough?
    2006 Mazda 3
    Behringer DCX-2496
    JL500/1 JL10w6v2
      Thanks, this is good to know.
      {Xenarc 700TSV} {Celeron M 1.3 ghz} {ASUS mATX mobo w/CT479} {MX440 128mb AGP} {1x512mb RAM} {3.5" Seagate 40gb (rated at 350 G's)} {M1-ATX}
      MY INSTALLATION LOG
        i don't think the fiberglass resin itself would give enough structural integrity to actually make a subbox out of it... as for other fiberglass parts that aren't load bearing, go for it... but for a subbox i would say no go.
          ...it uses fiber glass resin? I thought this used a different type of resin "casting resin", thought it may have been stronger, and yeah, no way is fiberglass resin strong enough for...... anything, lol
          2006 Mazda 3
          Behringer DCX-2496
          JL500/1 JL10w6v2
            ugh, guess my post didn't go through bleh. i just wrote a long response to that. But working with standard all purpose fiberglass resin, the fiberglass matting adds the strength paired with the resin itself, using JUST a type of resin to itself with no structure i really wouldn't trust it
            then again, i honestly have never worked with Casting resin, so i'm not 100% sure how that would work out. I jsut re-read the post and realized it wasn't any type i've ever worked with
              i've actually used that exact resin and it's tough, not tough enough to make a box nor is it cost effective but for smaller parts it works great. i recommend using smooth on for your molds since it's so easy to work with then use that same clear resin for your clear part (it's pretty cheap compared to smooth-on's clear resin) you can also buy dye to change the color of your parts.
              's
              New System in progress:
              M10k
              Phaze TD1500 ~> Seas g18rnx/p
              Zapco Ref 500.1 ~ 12" tc-9
              Transflective Xenarc
              My Car Pc Install
              My Boat Pc worklog
                ^^guess that figures it for us not possible for a sub enclosure
                  eh woulda been cool, oh well...
                  2006 Mazda 3
                  Behringer DCX-2496
                  JL500/1 JL10w6v2
                    i agree... that would be a very nasty sub box... completely see through... and when you blow your sub, you can get a nice smoky mix in the subbox that you can see
                    we had this kid come in with his sub one time, completely blown in a MDF box with 1wall plexi, he messed up the install and was like "Is this sub bad?" All you could see was smoke...
