Where to put the LCD? Help from experts needed :)
  • Where to put the LCD? Help from experts needed :)
    Hi guys... I'm a newbie and I'm started using a carputer in my Rover 200 MK3. However, the work isn't finished...
    My problem is that the touchscreen I have (a lilliput 8.4") is too big to be placed on central tunnel, so... where I can put it?
    Just looking for a permanent installation (at the moment, i put the monitor on the air tubs(???))
    Sorry for my bad english, and thanks for the help in advance!!!
    I'm pretty sure you can fit it in your center consel if you remove you head unit and the cig lighter under it.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
      cut the center bar just below the HVAC stuff.
      Remove the ashtray, remove teh radio, move the HVAC down to where the ashtray/radio is. Embed the screen where the AC and radio Was.
      You could also relocate the buttons on top o the HVAC.
      It's what I did to my bezel and I fit a 8.4" screen
      Car : 00' Chrysler 300M
      Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
      Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
      CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
        Hem... but I need the radio and cigars too!!! The radio is the source in/amplifier from carputer audio, the cigars lighter to take lcd 12v...
          you can move the radio to the glove compartment.
          and for powering you screen, don't use the cig lighter. Get the power from you power supply
          Installed
