How do I build up ABS?
  • How do I build up ABS?
    I am looking to work with the ABS sludge that has been talked about. My screen is about half an inch off on all 4 sides and I need to figure out how to build it up.
    (The screen fits into the dash, but has a opening about 1/2 inch all the way around)
    Is there a way for me to build up ABS?
    yea, find a sheet of abs. local plastic supply houses or hobby shops might be able to help.
    1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
    Pictures
    Photobucket is being updated, if a picture i posted no longer works, please PM me.
      take the whole piece out and use painters tape. Place the dash piece face down, level the area. Place the screen in the exact position you want it in the gap. Pour ABS sludge around the bezel into the gap between dash piece and bezel. Make sure you pour slow to avoid air pockets. Let dry and sand away. That's how I would do it at least.
        Man, I would have to disagree with this. The abs sludge WILL warp your bezel, I know, I just worked with it. I read a thread on this site about Dynatron and went that route and it worked great. I used ABS sludge to make a mold, carved it out and then used Dynatron to bond the 2 together.
        Just my $0.02
        http://www.mp3car.com/vbulletin/show...t-monitor.html
        "Imagination is more important than knowledge." -AE
          i agree, the abs sludge dissolves the existing ABS, and warping can occur. I'd use a sheet of abs cut to fit. Then if you wanted to bond the abs to the existing abs, a very small amount of sludge around the joint, applied like glue, would dissolve the abs and the acetone or MEK will evaporate, and the abs would be chemically bonded together.
          2007 Chrysler PT Cruiser TE
          Car PC Progress:
          View my
          Worklog
          Road Runner Skins
          Website
          Favorite thread EVER!
            Just get a cheap soldering iron with some abs sheets. Cut the sheets into thin pieces and plastic 'weld' everything together. It is structurally sound, I dont understand why people even bother with that sludge stuff
              I use the sludge (actually commercial abs cement found at home depot, basically the same, just pre-mixed) to glue the pieces together, and fill small holes or gaps. For anything larger than a small gap, I cut the abs sheet to size, and glue with the sludge.
              Car PC Progress:
              View my
              Worklog
              Road Runner Skins
              Website
                http://www.mp3car.com/vbulletin/fabr...k-warning.html
                Brian @Nexations Creations
                Specialist in Custom Interior Fiberglass OEM Replication Work.
                AIM: Exus28
                E-Mail: [email protected]
                  I saw that thread, I really like your work with the bezel. That is a good alternative as well. Do you happen to know the chemical properties of that stuff? I'm sure it bonds, but I still believe that the best thing to bond with ABS is ABS.
                  Car PC Progress:
                  View my
                  Worklog
                  Road Runner Skins
                  Website
                    Right of course ABS to ABS would be ideal, but in terms of this epoxy putty, just the normal procedure should be followed in anything to prep plastic to have something adhere to it, with the putty, I usually take down the plastic with 50 grit, and hit it up with Bulldog Adhesive Promotor before applying the putty
                    AIM: Exus28
